It is currently Tue Nov 18, 2025 10:10 pm
PostPosted: Wed Jun 25, 2003 8:09 pm
coming from my front end. This one is a squeal. It oscillates so I figured the bearings were shot. Replaced both sides inner and outer and the squeal remains. It quiets down while making a left turn and gets louder when making a right. Its just consistent while driving straight. Its a 63 valiant with power steering. Any thoughts. Thanks....g.
PostPosted: Wed Jun 25, 2003 9:53 pm
It sounds like one of your right side bearing races (most likely outer) is spinning in the hub. My 10" front drum, passenger side did the same, and was able to fix it by putting green lock tight around the outside of the race and putting it back in. This was 2 years ago and it still holds. I had to try several new bearings and races to find one that fit "kinda" snug, then put the lock tight in. It has to be the green stuff! If the hub is to far gone (inside to scored or out of round) this will not work and you will need a new hub.
PostPosted: Thu Jun 26, 2003 4:18 am
i had a bearing type noise on my '63 valiant once. it drove me crazy since the bearings seemed fine. it went away/changed around corners/turns. it had the original 13" wheel covers on it. when i took these off, the noise went away! must have been a gm design! :wink:
-james
 Post subject: This forum rules....
PostPosted: Thu Jun 26, 2003 5:51 pm
It really is amazing. I thought I was going to have to bang out those new bearings I just put in yesterday when I figured I'll just pull my hubcaps and give it a go. So, on my drive home from work...not a peep outta those wheels....so I got to enjoy the sweet sounds of the manifold leak and the rotten muffler all by themselves. Lucky me. Thanks James!!
PostPosted: Thu Jun 26, 2003 8:01 pm
glad i could help! :wink:
-james
 Post subject: Too Much Work
PostPosted: Sat Jun 28, 2003 7:22 pm
Y'all go to way too much trouble for a little old noise. Whenever I hear a noise in my car, I turn up the stereo and it disappears... :idea: :idea:
PostPosted: Sat Jun 28, 2003 8:49 pm
If I get a '63 Valiant, remind me to take the hub caps off. :shock: :wink:
 Post subject: Re: Too Much Work
PostPosted: Mon Jun 30, 2003 12:41 pm
Ha ha, the mexican way, only way to go :lol: :lol:
Si señor...
Rafa
PostPosted: Mon Jun 30, 2003 11:59 pm
I tried that on a Escort. After a few months the bearing wore thru and I had to replace the whole hub and drum. Then I found out, that there were two sizes of drums for that year, and of course mine was the smaller, not so common one. The local autoparts store wanted over $100 for a new replacement! After taking just about every drum off, on every Escort in the local pick-n-pull, I found the right drum.
The moral is that a $10 bearing is quicker and easier to replace then spending a whole day in the junk yard looking for a replacement.
