It is currently Tue Nov 18, 2025 5:40 am
 Post subject: Mystery part?
PostPosted: Sun Jul 06, 2003 1:54 pm
I found a relay looking part underneath the glove box in the Dart and I can't for the life of me figure out what it is. It's kinda purple in color and the part # is 2983872 and underneath is 93596-A. It's got three connectors on it and I couldn't find it anywhere in the wiring diagrams.
Any thoughts?
And also, how can I check the voltage regulator and condensor for the instrument panel to make sure everything's still good?
PostPosted: Mon Jul 07, 2003 9:52 am
Could it be the turn signal relay?
PostPosted: Mon Jul 07, 2003 11:08 am
You mean the flasher? Nope. I changed that one out just a few months ago. The flasher's a little round thing that I found under the factory radio.
PostPosted: Mon Jul 07, 2003 11:19 am
Site Admin
It could be a door buzzer of some sort. You didn't mention the year of the car.
As far as checking the voltage regulator, I would check the voltage at the fuel gauge. One of the terminals should read about 5 volts in about one second pulses. Bottom line is that if the gauges are working, don't mess with it.
Chuck Rivers, Webmaster
Image Image Image Image
PostPosted: Mon Jul 07, 2003 2:57 pm
It's a 1970, the basic Holley 1920, no-extras, 7 1/4" axle model.
The voltage regulator turned out to be the original mechanical one, so I went ahead and changed it over to an electrical using the DIY guide from Mopar Muscle.
PostPosted: Mon Jul 07, 2003 3:53 pm
It could be the 4-way flasher relay.
PostPosted: Mon Jul 07, 2003 3:54 pm
I found that next to the steering column while trying to tear out the instrument cluster :P
Still perplexed...
PostPosted: Mon Jul 07, 2003 4:35 pm
What year? It could be a disconnected seat belt buzzer had one on my 78 removed it the same day I got the truck Bruce J.
78b4ramSnortbed/6
PostPosted: Mon Jul 07, 2003 9:34 pm
I wasn't sure if A bodys had the flasher relay mounted there also. Thats also where it is in my Satellite and also on my late '70 Fury. You got me!
PostPosted: Wed Jul 09, 2003 8:56 pm
What year Dart? My Valiant(1975-6) have the HORN RELAY mounted on the left end of the plastic glove box. The tab on the relay fits a slot in the glove box.
PostPosted: Wed Jul 09, 2003 9:06 pm
It's a '70, but it was made right at the 69/70 cutoff, so I see alot of '69 parts that work with it (such as the 68/69 instrument cluster :roll: ) and vice-versa. This was bolted to the actual sheetmetal of the dash, underneath the glove box. Has three connectors on it. I would think it it were any kind of relay it'd have four connectors wouldn't it?
