It is currently Tue Nov 18, 2025 5:16 pm
 Post subject: Dash dimmer control
PostPosted: Sat Jul 12, 2003 2:17 pm
So during my electrical escapades under the dash of the Dart, I'm also moving the Sony receiver up into the dash to replace the factory radio. The wiring will be really simple, save for one question. The Sony has a "dimmer" lead for attatching to the dash dimmer circuit.
What I can't figure out is which lead on the headlamp control knob is for the dimmer/dash lighting! That's a burly plug and the wiring diagram didn't help much :|
I want to wire that out to a small distribution box that I can easily connect the receiver's and the aftermarket gauges' dimmer leads to for a clean wiring job.
PostPosted: Sat Jul 12, 2003 2:27 pm
What I did for my aftermarket gauges was to feed the light from the fuse box, I believe I put it on the headlamp fuse, I can't be positive. I will check next time I am at my car if you want me to. Lots easier then reaching all the way up to the dash. If memory serves me right I didn't need to tap into any wires the extra spade terminals were already availible on the fuse box.
PostPosted: Sat Jul 12, 2003 3:43 pm
That's what I had originally wanted to do, but as anal as I am about keeping things consistent, I wanted to have the lights on the dimmer circuit :P
PostPosted: Sat Jul 12, 2003 5:27 pm
That fuse is on the dimmer circuit.. ahh wait maybe it wasn't the headlight fuse there is a fuse in the block that goes to the dashlights... that one is deffinately tied into the dimmer function. My add-on gauge light deffinately varies brightness along with the dash lights when you turn the headlight switch knob.
PostPosted: Sat Jul 12, 2003 5:33 pm
Ah okay. Running that to a dist. block would be the best bet then. Sweeeet...
PostPosted: Sun Jul 13, 2003 9:20 am
Jopapa, If you are using a fused distribution block, be sure that you don't fuse the ground (negative) wire. Although it is unlickely that the head unit would blow a fuse, should something short or malfunction causing a fused ground to blow, it will look for a ground somewhere else. That can cause a serious problem :shock: The ground for the head unit should be as short as posable and go right to the fire wall. If the Sony your using is driving the speakers (no additional amplifier) and it is a "high-powered" unit, it's a good idea to get the constant power directly from the battery. Run 10 gauge wire through a grommet in the firewall with a fuse at the battery. If it's not high powered, it's OK to get power right from the factory fuse box, or even better, off of the ignition harness. I usually don't recommend using the factory radio harness in older cars, and they usually won't have constant power anyway.
Dan M.
PostPosted: Sun Jul 13, 2003 11:07 am
If your lucky like I was, there should be some unused female connections under the dash that you can plug into. Depending on the year, they should be orange (dash light wire). I pluged my tach and oil guage light in to this pig tail and have dimmer controll like the dash lights.
PostPosted: Sun Jul 13, 2003 11:29 am
There are a bunch of plugs under there, that's for sure. I suppose I could check with a voltmeter and find out which varies with the dimmer adjustment...
 Post subject: Suggestion
PostPosted: Sun Jul 13, 2003 2:09 pm
Jopapa while your in there terminate your speaker leads to a terminal strip in one side and the harness leads to the other this way you avoid having to cut the harness if you ever change the unit. Included 8 1/4 12V taps when new harness was constructed this wires directly to the switched igination side of the fuse block with independent fuse protection for all 3 circuits am currently using (gauges, radio,spare). Next project how to hang some speakers in the overhead and yet keep them hidden by the headliner...........Dave
Users browsing this forum: Ahrefs [Bot] and 9 guests
