It is currently Tue Nov 18, 2025 5:05 am
 Post subject: Will bee adding weight
PostPosted: Mon Jan 17, 2011 9:42 pm
Got my car down to 2355 lbs with driver.I am now concentrating on getting rotating weight down,lighter wheels,brakes.Will have to run 6 more gallons of gas to stay in my weight class.I useally run with 2 gallons in tank,will bee running 8 when I try to lower my B gas record.Wheels I just ordered are extreamly light.Do the math and you can figure out how much rotating weight I am takeing off.Aluminum driveshaft only took off 3.5 lbs.I also shaved 5 grams off each of my nuts.Nice part about adding fuel is that its at the very rear of the car.Guzzi Mark
PostPosted: Tue Jan 18, 2011 6:46 am
Get some titanium lug nuts.
11.02 @ 120.56
Chassis dyno
PostPosted: Tue Jan 18, 2011 9:59 am
What kind of razor, and what kind of anesthetic?? :oops:
Seymour is drilling holes in his car all winter too... :twisted: :wink:
PostPosted: Tue Jan 18, 2011 10:48 am
While on the subject of "NUTS"!!... :roll: :lol:
PostPosted: Tue Jan 18, 2011 11:50 am
Double-bitted axe and Aqua Velva.
PostPosted: Tue Jan 18, 2011 2:35 pm
That musta hurt! :shock: :lol:
PostPosted: Tue Jan 18, 2011 3:08 pm
PostPosted: Tue Jan 18, 2011 3:55 pm
When I worked at the race car shop I was entrusted the job of ordering titanium fasteners for the NPS Camaro project. $1500 worth of Ti bolts saved just about 4 pounds off the car. :shock:
It will be interesting to see if the wheels reduce ET any. I have never seen a drag car actually lose ET from a set of wheels. Show me the way Mark. :D :D
PostPosted: Tue Jan 18, 2011 4:54 pm
From what I have read,,takeing 1 pound of rotating weight off equals 4 pounds of static weight off car.So in theory by takeing 40 lbs of rotating weight off my car its like takeing 160 lbs out of the car.I am hopeing for a 10th off et.with just the rotating weight change.Testing of this and the Hurricain manifold will bee done seperately.We will see.Guzzi Mark
PostPosted: Wed Jan 19, 2011 6:16 am
I have dropped time (up to 0.1 sec) on more than one car by back-back wheel swaps/runs at the track. Recently, I replaced the 47 lb road course wheels/tires on Project V with 31 lb drag skinnies, and that netted about 0.1 sec.
PostPosted: Wed Jan 19, 2011 8:05 am
Ever thought about a full body wax?? :shock: Every gram counts
10.74 @ 127.47 mph 1320 ft
6.65 @ 107.80 mph 660 ft
http://www.youtube.com/c/turbo66valiant
Follow on Instagram - turbo66valiant
Facebook - https://www.facebook.com/ryan.peterson.737
PostPosted: Wed Jan 19, 2011 1:54 pm
That might work for a hairy guy like Sandy... :lol:
Not sure about Mark.
For the European Swim Championships one year my boys all shaved their heads for better "aguadynamics"... That's a few grams of weight for sure! :lol:
PostPosted: Wed Jan 19, 2011 2:40 pm
Poser
Sell off a kidney? I had the opportunity to help with a factory hemi Dart drag car. Rick Allison traded a Pro Stock Plymouth Arrow for the car.
It was interesting to see the super thin side glass and the acid dipped bumpers etc. When we started to work on the car we discovered every damn bolt, nut & what have you, was titanium. :shock:
Pulling off the trunk lid was quite an adventure - we nearly got hernias... Some one had doctored it up but good!
 Post subject: Car
PostPosted: Wed Jan 19, 2011 7:39 pm
There are other ways to take a few lbs off.... More in the medicine aisle at your local drugstore. GOOD LUCK MARK!
BIG T
1967 Dart "Six Shooter"
Girlfriend Rhonda... 66 Valiant
Image[/URL]
PostPosted: Fri Jan 21, 2011 7:44 pm
So mark, I know you are adding Fuel and bumper for the B and C record..
Do you use one of the ALuminum Pigs for the 8 3/4?
I know they are a bit pricey, but they are maube 15-20#'s lighter than the cast FE ones.. and It might help you to get closer for the A weight.
