It is currently Tue Nov 18, 2025 2:10 am
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Sat Feb 12, 2011 8:18 pm
sooo.... opened her up again, drained the oil... i now smell like gas.. got a new fuel pump... it was an original *still had factory hose clamps on it*
so update!:
1) fuel pump-installed
2) oil pump= tomorrow install
3) shocks still in trunk for next weekend
4) brakes next weekend as well...
74 plymouth duster, 225 single barrel slant six
PostPosted: Thu Mar 24, 2011 4:16 pm
late update:
last weekend replaced timing chain
still serious lack of power
last weekend (as in the 19th of march 2011) i tested compression, 135 PSI was highest, 119 Was lowest. so fine *i hope tell me if i am wrong*
this weekend, test for vacuum leak... and if that is fine... i hope to jebus its fine but if vacuum leak isnt the problem... -.- we are going back in to see if the timing chain is lined up... -.- pray for me that it isnt that... and i aint even religious... pray to the car gods that it isnt timing... (click and clack are fine to pray to)
 Post subject: I love your car!
PostPosted: Wed Apr 13, 2011 8:09 am
Okay I love your car for a lot of reasons but here are the two main reasons! 1) Its a duster 2) I own a '73 duster that looks EXACTLY like the one in your pictures at the beginning of your subject, only difference is mine has steel wheels with center hubcaps. I'm 17, and i bought this car as my first car when i was 15. I can't wait to get the money and time to fix mine up like your doing to yours. Good luck!
To live doesn't mean you're alive.
1973 plymouth duster forever!
PostPosted: Wed Apr 13, 2011 4:32 pm
thank you, i have had a slow down on mine because of lack of funds and failing computer parts, but i hope to get mine up on the road
PostPosted: Thu May 12, 2011 2:15 pm
so a little update, removed the valve covers... not to bad not to bad at all, 37 years of gunk and it looks pretty good i was expecting some bad stuff like thick oil with metal shavings and birds nests with kitties... but not just some gunk...
soon i will be screwing with the engine a bit more to try to get everything going right again...
PostPosted: Thu May 28, 2015 8:50 pm
wow it has been a long time, but i am back.
I have been slowly working on the duster.. and by slowly i mean almost not at all.
Update on the duster (now dubbed ruster due to vinyl roof eating away at my roof and my heart :( ) got a line on a few things, and it may result in my 74 duster leaving the slant six field and move onto the 360 v8 or 383 v8 field.
