It is currently Thu Nov 20, 2025 3:52 am
PostPosted: Fri Aug 22, 2003 3:02 pm
My fuel and temp no longer work, is it probably the voltage limiter? Do these malfunction regularly? Would Napa or Auto Zone or Checker have them, were are they located? Sorry for all the questions it just has me stumped. The car is a '62 Valiant, thanks.
-Jesse
PostPosted: Tue Aug 26, 2003 12:35 pm
voltage limiter on the back of the gauge cluster .drop the steering column ,unscrew i think 6 screws holding the cluster. pull it out. unplug lights, wipers, and speedometer.limiter is top center. should be able to get it at any parts house
73 swinger holley 5200, 2 1/4" exhaust .030 over new pistons , cam, .010 under crank. stock everything else. 1/4 mile about a week. 0-60 around 15 sec.
PostPosted: Wed Aug 27, 2003 6:29 pm
Actually, on a '62 the voltage regulator should be integral to the fuel gauge. Check out Chuck's article in the "articles" area on this site, it shows how to hook up the newer external VR to the older instrument panel. The best part is if your internal VR is totally dead, it should restore full functioning of the gauges. Might look into building a solid state 5v VR while your at it, all the parts are available at radio shack for about $5. There was a link here a while back to a great thread on moparts.com as to how to do this. I've got all the parts ready, and just need to find time to put it together soon. :)
