It is currently Tue Nov 18, 2025 9:14 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Fri Mar 18, 2011 1:18 pm
So welding a flange to the stock exhaust manifold is not a good idea? Or (with NO disrespect to Wayne) was it done poorly? I liked the look of the mount, but could it have been further supported? This is going to be my first turbo build (as I guess is obvious) and the actual mounting of parts is a concern.
________
LITTLESWEETY
PostPosted: Fri Mar 18, 2011 6:07 pm
welding low quality cast such as the prone to crack slant manifold is not a good idea, it will crack .you'd be better off bolting on an elbow off of the original flange to a remote mounted turbo than welding a flange derectly to the manifold for the turbo
Nick
86 d150 turbo /6.
64 valiant 4 door
PostPosted: Fri Mar 18, 2011 8:23 pm
Okay, that makes sense as well. Can any of you who responded show me images of how your turbos are mounted?
________
WildCATblond
PostPosted: Sat Mar 19, 2011 10:40 am
A pair of the Dutra exhaust manifolds with a T connection would also be a good choice.
I have thought on this for a long time. I would also use TBI in a draw thru setup. Simple to build and the TBI should fix any preconceived problems with carburetors. Especially if you use a Megasquirt and control the ignition also.
PostPosted: Sat Jul 09, 2011 10:02 pm
I opted for a small turbo, an IHI from a turbo coupe. I fabbed an adapter out of a stainless elbow and welded a bracket to my motor mount, but I have a lot more room under the hood than guys with newer cars.
This turbo pulls to 5000 RPM, I would have considered 4200 a success. I just want a fun car with all the grunt on the bottom.
If you pick a popular turbo, flanges to make your down pipe and adapter are a dime a dozen, If you pick a strange one (like mine) you've got to make your own.
My advice? Listen to everyone. Then make choices that you can live with not fight with.
1960 Seneca 225 turbo soon to be EFI
