It is currently Mon Nov 17, 2025 2:51 pm
Post new topic  Reply to topic  [ 43 posts ]  Go to page Previous 1 2 3
PostPosted: Thu May 26, 2011 9:19 am
its the stock steel hood with the braces cut out of it and not hinges or latches
1967 Dodge Dart
PostPosted: Thu May 26, 2011 10:24 am
I have a mopar per. ignition control unit
Not a good one. Do the HEI upgrade.
kem high per. plug wires
www.magnecor.com
accel super coil
Dinosaur. See the HEI article.
PostPosted: Thu May 26, 2011 10:42 am
Hi Russel Cable,
There is another racer on Newfoundland who is a member here, and he is always extremely helpful when presenting solutions to member's problems here in the forum, so I am sure he can assist you.
So my advice is, follow this link to terrylittlejohn, and send him a pm.
BTW, too much advance gives lean-out symptoms, the retard advice is good.
Olaf.
Aspenized
PostPosted: Thu May 26, 2011 11:41 am
The car still seems lazy off the line what was your 1/8mile time so i can compare my times for the old motor because i've only raced the 1/8th. My heavier duster would do 1.9 60foots with a 3000rpm converter and only 3.73 gear. Similar engine setup like yours except with a 390holley. This was with the erson 270cam same valves/headwork and .100 off the head with a 40overbore 9.9:1 compression if memory serves after some off the deck. For 13's spray from the line all the way down the track :)
Id have to dig a timeslip out when the car was auto but i'm 99% positive my time was
!.9 60ft
9.6 1/8th @71
Kev
PostPosted: Thu May 26, 2011 2:42 pm
I dont think there is a 1/8th mile timer at the drag strip. There is a 1/8th mile strip opened up last year here. we never had the car on the 1/8th mile yet, maybe next year when its done.
1967 Dodge Dart
PostPosted: Thu May 26, 2011 3:44 pm
Not a good one. Do the HEI upgrade .
www.magnecor.com
accel super coil
The car has a MSD 6A ignition box with a mopar (i think) distributer and 8 mm plug wires[/quote]
1967 Dodge Dart
 Post subject: hi
PostPosted: Thu May 26, 2011 7:46 pm
it been a while but just to up date i been driving and raceing this car for about 10 to 12 years now and terry littlejohn and myself been friends a long time now he got me into bilding slant 6 motors but i seen it is time to pass the car on ot my son chaz who just joined he helped bild this car starting when he was 3 years old it is a fun car and fast it ran a 13.9 with a small shot, off the line and on the dyno it was 150 hp and 229 foot of touqe with no shot just motor but it is his turn to have fun
PostPosted: Tue May 31, 2011 5:42 pm
I'm wonding if an MSD distributer would be a better upgrade from the mopar thats on the dart now? Also what about a deep sump oil pan?
1967 Dodge Dart
PostPosted: Wed Jun 01, 2011 7:23 am
whats your rt ?
slant six's RULE!
http://www.usajon.com
PostPosted: Wed Jun 01, 2011 5:14 pm
i can't remeber, its been a while and i cant find timeslips, but i know it was pretty quick
1967 Dodge Dart
PostPosted: Sat Oct 08, 2011 3:42 pm
I have a 67 dart 225cyl. bored .060 plained .030 and .115 cut off the head. The cam is a Comp Cam .490 lift 230 duration at .050 and 340 valve springs.
the valves are 1.78 intake 1.50 exaust . A 650cfm 4BBL carb with a 6 into 1 header. the car has a 904 trans. 2500 stall tork 4.56 gears and is only 2650 lbs.
So why is my ET. 15.2 and MPH 89.9????
What am i doing wrong.
I will attempt to help,
If you are using a tire diameter of 26inches +/- then you are turning the engine around 6100 rpm considering a torque converter efficiency of 96% or better. Your cam specs are not fully given but if your lobe seperation is around 110degrees then your peak horsepower should happen at around 5700-5900 rpm. I suspect that you are hitting that engine speed before you reach the finish line. Remember that stock sl6 engine assemblies should not exceed that rpm. Rough calculations tell me that your combination should net ET's around 13.9-14.3 with trap speed at around 100 mph. You may want to consider a gear ratio of 4.10 or perhaps even a 3.91 if you plan on increasing engine output further.
Another item that I would address is your carbeurator size. It seems to be too fat for a SL6. Cfm of 500 or lower would perform better. Be sure to jet properly for your engine combo.
You can safely remove .100" of material from a SL6 head. this will raise the comp ratio of a 225 to about 9.8:1 depending on head gasket thickness. and block deck height. You will notice an improvement by doing so.
How is your 60 ft time? Can you get start line rpm up to 2500 using foot brake? If not then you may want to increase stall speed.
The rest will require the usual fine tuning: cam degreeing, advance curve, hot spark, cool plugs, tire pressure etc, etc, etc...
Hope this is some help.
Best eregards,
Ken Gibbs
PostPosted: Sat Oct 08, 2011 4:29 pm
When I responded to your question I did not pay attention to your posting date. You probably have the answer all figured out by now so disregard my input from earlier message.
Cheers,
Ken.
 Post subject: re
PostPosted: Sun Oct 09, 2011 5:38 pm
I have passed this car on to my son but i did take 100 of the head and 100 of the block and the carb is not to big the 650 workd very good on the street and at the track with small changes it runs now as it did the problem was the transmission was sliping i found it when the car was on a dyno and also added 100 shot of nitros it been over 10 years of street and strip abuse and still runs good
