It is currently Mon Nov 17, 2025 8:07 am
PostPosted: Sun Jul 17, 2011 3:18 am
my machinist bro ran a temp unit in #1 exhaust header as He was running alcohol, and he could tune the carb to get the right temp and that would tell him the OK point for the engine..
anyone ever run one for gas use?
slant six's RULE!
http://www.usajon.com
PostPosted: Sat Jul 23, 2011 8:10 am
SSRN National Champion
yea i run on the number onn clyinder on racing fuel Thanks Ron Parker
PostPosted: Wed Aug 10, 2011 10:05 am
yes you can... but what about cylinder 2 and three?
the fuel distribution is all skewed between cylinders due to the intake...
this is why im building a tuned length manifold...
so if you wanted to do one better you should do cyl 2 so you get a median...
P.S. why not run wide bands instead...
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
