It is currently Tue Nov 18, 2025 8:46 am
Post new topic  Reply to topic  [ 382 posts ]  Go to page Previous 1 2 3 4 526 Next
PostPosted: Tue Jul 19, 2011 4:17 pm
My BAD.Mark
PostPosted: Tue Jul 19, 2011 6:09 pm
I think I might have made up the 3250 without checking when I sent those new records to Ryan. The worksheet that I send into the newsletter shows 3200 for the class D minimum.
PostPosted: Tue Jul 19, 2011 6:21 pm
Bad boy Seymour. You shall be soundly flogged with a coil wire from a 144 ci Falcon motor. :lol: :lol: :lol: :lol:
PostPosted: Fri Jul 22, 2011 9:57 am
I don't remember specifically when/how we came to the upper limit of 3199 for C class, but even at that it is 150# more than the three lower weight classes.
It should cover a lot of the more serious street/strip cars out there. I think my street dart with full interior and no lightweight parts whatsoever weighs in at 3250# without driver.
Mark's gonna add enough weight to have the gas records in A, B, C AND D! :D
PostPosted: Fri Jul 22, 2011 7:42 pm
Been working on getting 350 lbs in the car,got just over 80lbs into rear bumper.Adding is allmost as hard as takeing it out.I wont even try for the D.Will bee makeing a 100 lbs passenger seat,Big spare tire mounted in front of fuel cell just behind axel will bee close to 100lbs.There are rules for adding ballast and I will do it correctly.Borrowed a 85lb chunk of lead from a friend today.My goal is 11.85 @ 2710lbs.Guzzi Mark
PostPosted: Fri Jul 22, 2011 8:57 pm
DOC,needs to finish up his new motor or I will put a 5 shot on my motor and take his weak B nitrous record.And I will do it in Vegas.Trying to motivate the Doc.Guzzi Mark
PostPosted: Fri Jul 22, 2011 9:28 pm
6 Pack Dart
Mark, you must be a record setting freak. :roll:
Try going for the best street mileage :lol:
Richard
PostPosted: Sun Jul 24, 2011 6:29 pm
I just changed the last record sheet to say 3200 lbs for D class. I was thinking it was 3250, but I was at Lou's house today and he told me it is 3200. Lou also weighed my car for me. 3380# with me in it, so I can cut 180# out. I was hoping to set an 1/8th mile nitrous record at elk creek, but wasn't able to get that working. Charlie also broke so i'm not sure if he was able to set a nitrous record (he broke on what would've been his backup run). I think there were a few other 1/8 records set for the D class that will need turned into Seymour.
Ryan Covalt
PostPosted: Sun Jul 24, 2011 8:19 pm
Thanks, guys. Charlie did make a 2nd pass and he said it was in the 8s, so that slower time can be his record.
You think your car is heavy, my '68 turbo Dart is a portly 3455 lbs with me and a full tank. I doubt I can get it close to 3200 without sacrificing luxury+touring car status. I am brainstorming....
PostPosted: Sun Jul 24, 2011 9:09 pm
Thats good for Charlie, at least we will have an 1/8th mile nitrous record in the books, and you will have the unlimited record too. I'm sure you'll find a way to get some weight out of the Dart without losing the touring status. Thanks for everything this weekend it was a blast.
Ryan Covalt
PostPosted: Fri Jul 29, 2011 10:06 am
Here are the update records as of 7/29/11
All records in red are new for 2011
Weight of 2000-2349#
Class .......Date.............Driver...................Record..........ET/MPH
Gas Only
A/G......7/16/11.....Mark Etheridge............1/4 Mile ET.......11.436
A/G......7/16/11.....Mark Etheridge............1/4 MPH...........115.51mph
A/G......10/14/06...Seymour Pederson......1/8 Mile ET..........7.250
A/G......5/8/04.......Dale Rose...................1/8 MPH...........92.632mph
Alcohol Only
A/A......5/22/11......Will Burns...................1/4 Mile ET........11.441
A/A......5/22/11......Will Burns...................1/4 MPH..........117.92 mph
A/A......10/14/06....Norman Foster.............1/8 Mile ET.........7.355
A/A......10/14/06....Norman Foster.............1/8 MPH...........92.39 mph
Nitrous
A/N......5/19/02......Will Burns....................1/4 Mile ET......10.943
A/N......5/19/02......Will Burns....................1/4 MPH.........125.53 mph
A/N......5/8/04........Will Burns....................1/8 Mile ET........7.042
A/N......5/8/04........Will Burns....................1/8 MPH.........99.752 mph
Unlimited
A/S......4/19/08......Dale Rose....................1/4 Mile ET......10.012
A/S......4/19/08......Dale Rose....................1/4 MPH.........132.82 mph
A/S......5/8/04........Tom Drake...................1/8 Mile ET........6.102
A/S......5/8/04........Tom Drake...................1/8 MPH........109.89 mph
Weight of 2350 -2699#
Class .......Date............Driver....................Record.............ET/MPH
Gas Only
B/G......9/12/10.....Mark Etheridge.............1/4 Mile ET........11.50
B/G......7/17/11.....Mark Etheridge.............1/4 MPH..........114.860 mph
B/G....10/14/06.....Seymour Pederson.......1/8 Mile ET.........7.333
B/G....10/14/06.....Seymour Pederson.......1/8 MPH............91.91 mph
Alcohol Only
B/A.....9/6/03........Brent Lanely................1/4 Mile ET........10.710
B/A.....9/6/03........Brent Lanely................1/4 MPH...........120.81 mph
B/A.....5/13/06......Ron Hamby..................1/8 Mile ET..........7.600
B/A.....5/13/06......Ron Hamby..................1/8 MPH...........87.783 mph
Nitrous
B/N.....7/12/08......Doug Dutra...................1/4 Mile ET.......12.845
B/N.....7/13/08......Doug Dutra...................1/4 MPH..........103.93 mph
B/N..............................OPEN RECORD.......1/8 Mile ET
B/N..............................OPEN RECORD........1/8 MPH
Unlimited
B/S..............................OPEN RECORD........1/4 Mile ET
B/S..............................OPEN RECORD........1/4 MPH
B/S..............................OPEN RECORD........1/8 Mile ET
B/S..............................OPEN RECORD........1/8 MPH
Weight of 2700# - 3249#
Class.......Date............Driver........................Record...........ET/MPH
Gas Only
C/G.....4/10/05......Mike Jeffrey...................1/4 Mile ET.......12.080
C/G.....4/10/05......Mike Jeffrey...................1/4 MPH.........108.70 mph
C/G....10/14/06.....Gary Bruner...................1/8 Mile ET........7.873
C/G....10/14/06.....Gary Bruner...................1/8 MPH...........86.77 mph
Alcohol Only
C/A....10/11/09......Jason Davis...................1/4 Mile ET.......11.279
C/A....10/11/09......Jason Davis...................1/4 MPH..........114.22 mph
C/A..................................OPEN RECORD.....1/8 Mile ET
C/A..................................OPEN RECORD.....1/8 MPH
Nitrous
C/N.....9/10/05........Mike Jeffrey..................1/4 Mile ET......10.542
C/N.....9/10/05........Mike Jeffrey..................1/4 MPH.........125.25 mph
C/N.....8/23/08........Charlie Schmid..............1/8 Mile ET........8.319
C/N.....8/23/08........Charlie Schmid..............1/8 MPH..........80.026 mph
Unlimited
C/S.....8/22/10........Ryan Peterson...............1/4 Mile ET......10.910
C/S.....8/22/10........Ryan Peterson...............1/4 MPH.........124.87 mph
C/S...............................OPEN RECORD.........1/8 Mile ET
C/S...............................OPEN RECORD.........1/8 MPH
Weight of 3200# or more
Gas only
D/G.....6/4/11..........Dennis Schumers............1/4 Mile ET......14.199
D/G.....6/4/11..........Dennis Schumers............1/4 MPH..........96.640 mph
D/G..................................OPEN RECORD.....1/8 Mile ET.......
D/G..................................OPEN RECORD.....1/8 MPH..........
Alcohol
D/A..................................OPEN RECORD.....1/4 Mile ET.......
D/A..................................OPEN RECORD.....1/4 MPH..........
D/A..................................OPEN RECORD.....1/8 Mile ET.......
D/A..................................OPEN RECORD.....1/8 MPH..........
Nitrous
D/N......5/23/11...............Charlie Schmid......1/4 Mile ET.......13.362
D/N......5/23/11...............Charlie Schmid......1/4 MPH...........99.65 mph
D/N..................................OPEN RECORD.....1/8 Mile ET.......
D/N..................................OPEN RECORD.....1/8 MPH..........
Unlimited
D/S..................................OPEN RECORD.....1/4 Mile ET.......
D/S..................................OPEN RECORD.....1/4 MPH..........
D/S..................................OPEN RECORD.....1/8 Mile ET.......
D/S..................................OPEN RECORD.....1/8 MPH.........
Ryan Covalt
 Post subject: Record Setting?
PostPosted: Fri Jul 29, 2011 10:36 am
Do I understand correctly that I could build a tube chassis super high compression race car set the A gas record and add weight over the rear axle and then set every record in every other weight class? Add nitrous then set all the nitrous records too? I don't have a race car yet but I would like to know the rules. Seems to me that the higher weight classes were intended for the heavier street style cars not for rails/race cars and the lower weight classes are meant for the race only cars? Is there a distinction between classes or is it open for a race car to set every record?
Ryan Covalt
PostPosted: Fri Jul 29, 2011 11:50 am
The way it's written now any "doorslammer" car can set any record as Mark is starting to do by adding weight. As long as your car weighs in with driver at a certain class and you back it up.
We had gone around and around a few years back with trying to get more "street" cars involved. There were as many opinions on what "street" meant as there were cars if I remember correctly.
The only class that makes a distinction on the type of vehicle is the AA super lightweight sub 2000# class that was just added. That class is just for rails, bikes and other interesting contraptions that are not "doorslammers".
PostPosted: Fri Jul 29, 2011 1:31 pm
AA includes doorslammers too, but it is hard to get them that light... There are a few out there that could maybe make <2000lbs.
PostPosted: Fri Jul 29, 2011 2:01 pm
I stand corrected. Thanks Lou.
I do remember that Dale Rose had to add some weight to his Arrow to meet the minimum weight for an A Class record now that you mention it.
Users browsing this forum: No registered users and 29 guests
