It is currently Wed Nov 19, 2025 6:32 pm
 Post subject: Holley 390 4 brl
PostPosted: Sat Aug 13, 2011 2:58 pm
Finally got rid of the flat spot in my hot rod . Passing anything was a pain in the rear and meant I had to slingshot past everything . I had the same problem with a single , two barrel and the 4 barrel Holley . Finally hit on this combo .
Holley 390
#31 shooter
#54 idle mixture screws
Fires right up and no longer bogs
I need to play with it some more to see if this is the perfect combo but it works very nicely as is . The idle mixture screws are out 2 full turns , so I may need to do some tweaking yet but I seem to be on track .
Hard to start when warm , fires in a sec when cold - one stab of the pedal and siimply turn the ignition on and it will fire without any pedal feathering or pumping .
The only thing original is the serial number and data plate.
PostPosted: Sat Aug 13, 2011 3:29 pm
Welcome to the forum, WC53.
You may copy your post text and put it in a new thread in the 'engine' section, there are many slantsixers running a Holley 390, and I am sure they are interested in this info. The reason for suggesting that you move it, is that it will be easier to find it in a search limited to the engine section.
The Slixer's Gallery is mainly used for pics of your car, so get out your camera and let us have the pleasure of viewing a photo of your hot rod! :D
Olaf.
Aspenized
