It is currently Tue Nov 18, 2025 12:05 pm
Post new topic  Reply to topic  [ 39 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Mon Aug 15, 2011 5:28 pm
here you go, i dont have a good photo of the whole car with the blower sticking out of the hood yet. maybe this weekend i will snap one while im working on it.
that's a nice wagon with/without a supercharger!
slant six's RULE!
http://www.usajon.com
PostPosted: Mon Aug 15, 2011 5:49 pm
holy crap thats a boat anchor of aluminium lol, but am amazing project so far !!
-Mike
I am the Guardian, I hate helos, everything leaks.......
PostPosted: Tue Aug 30, 2011 3:23 am
you just know it's gonna cock a front leg as it takes off from the line, flow restrictions or not!
Chris
The Wayfarers
six 'n out
PostPosted: Mon Sep 05, 2011 7:27 pm
i hope so. just an update, i dropped the blower off at a place called superchargerusa in la habra, ca this weekend. the guy there was real nice and took the time to pull it apart and show me what should be replace and what didnt need to be and why. he is also going to polish it up. i should have it back in a few weeks and then i can finally button this thing up and fire it up.
it's not only good. it's good enough.
PostPosted: Wed Sep 21, 2011 3:14 am
don`t worry, tapper the blower opening into the intake opening and you will have no problem with the blower charge. just take a look at the top fuel manifold, it`s tapered towards the front were most of the pressure pulse is directed and they have 14-71`s squeezing all that charge into a 1/4 of the blower size opening. nice setup you will be pleased. 8)
PostPosted: Sun Jan 01, 2012 3:28 pm
well i finally have an update. fired it up today to see if it would run. and it did. now for some tuning....
http://www.youtube.com/watch?v=FTi_x_Ru ... ata_player
PostPosted: Mon Jan 02, 2012 10:01 am
looks and sounds really good. what timing and psi are you setup for?
PostPosted: Mon Jan 02, 2012 12:29 pm
thanks. according to the formula on holley's site. this pulley ratio based on engine size and blower size should give me around 4 pounds of boost. not much yet. as for timing, i will need to pick your brains and do some searching on this site. when i started it up yesterday, i didnt even mess with the timing. all i did was plug off the vacuum advance. any tips are greatly appreciated.
PostPosted: Mon Jan 02, 2012 2:30 pm
i was given good advice here on this site when i first started, with a locked dist mech adv and only vac adv. set base timing at 15degs, no vac hose, then use adj screw in vac pod to get total timing to 25degs. you have to hook the vac hose to the intake not the carb, so when boost comes on the psi will push you back to base timing. i started with this and now have 20degs base at 12psi boost but i have also got water injection+supreme gas.when i ran the smaller 4-53 blower, i ran faster with 3psi than i did with 5psi. you will have alot of good times as you get the tuneup right and feel the car pushing back in your seat :twisted:
PostPosted: Mon Jan 02, 2012 2:51 pm
thanks. this is the kind of good info i was hoping for.
PostPosted: Sun Jan 08, 2012 5:43 pm
what size valves are you running?
PostPosted: Sun Jan 08, 2012 7:02 pm
stock size valves on a rebuilt head i bought, but i have a newer style head i picked up that i want to build eventually.
PostPosted: Mon Jun 04, 2012 6:47 pm
this is very helpful I am about to supercharge my 69 dart!
Good work!
PostPosted: Wed Aug 29, 2012 3:10 pm
just finished swapping the engiblder valve head 1.70int/1.44ex with my bigger valve head 1.80int/1.60ex the engiblder head ran a best of 11.48et@115mph 1.54 60ft with 12psi, the bigger valve head ran 11.15@120mph 1.47 60ft with 12psi, i had to use a smaller pulley to boost psi when it drop to 10psi after installing the bigger valve head.i am going to build another head with engiblder valve 1.81" bb dodge shorten and reduced to 1.80" for int and 1.70" reduce to 1.60" for ex. with the swirl polish and back cut they should flow even better
PostPosted: Wed Aug 29, 2012 8:18 pm
[quote="terrylittlejohn"]i was given good advice here on this site when i first started, with a locked dist mech adv and only vac adv. set base timing at 15degs, no vac hose, then use adj screw in vac pod to get total timing to 25degs. you have to hook the vac hose to the intake not the carb, so when boost comes on the psi will push you back to base timing. i started with this and now have 20degs base at 12psi boost but i have also got water injection+supreme gas.when i ran the smaller 4-53 blower, i ran faster with 3psi than i did with 5psi. you will have alot of good times as you get the tuneup right and feel the car pushing back in your seat :twisted:[/quo
This is great info I'm getting ready to start the tuning process and im going to give this a try
Terry are you adjusting the pod on the dizzy to 25degs at idle? And if I'm reading this correct your at about 20° locked and 30° total timing right now I was planning on starting at about 18° advanced so if i was going to adjust the pod I'd want to set it at around 28°?
Sorry for all the questions I'm just trying to understand better
Thanks Aaron
http://youtu.be/2Y4i4UOLiSA
http://www.forabodiesonly.com/mopar/sho ... p?t=126611
