It is currently Tue Nov 18, 2025 6:39 pm
 Post subject: Heater Delete
PostPosted: Tue Aug 16, 2011 9:45 am
What are you racers doing with the heater hose outlet/inlet on the water pump when you go heater delete? Anyone using caps? If so what are you using?
PostPosted: Tue Aug 16, 2011 10:05 am
I tap the hole and install a pipe plug. (upper pump in the photo below)
Remove the hose bib from the head and put a pipe plug in that also.
Keep the by-pass hose functional.
PostPosted: Tue Aug 16, 2011 10:08 am
Thanks Doc :D Off hand do you know what size pipe plug to use?
PostPosted: Tue Aug 16, 2011 10:23 am
Off-hand... 1/4 NPT for the water pump bib.
I use a tapered grinding burr to give the hole a little cone shape before tapping.
Be careful with the die cast aluminum pumps, it is easy to crack / split the bib. (try your tapping process on a junk pump first, to get a good "feel" for it)
PostPosted: Tue Aug 16, 2011 10:46 am
Using it to cool my turbo!!!!
11.02 @ 120.56
Chassis dyno
PostPosted: Tue Aug 16, 2011 10:54 am
Oooohh! I didnt think about that. I plan on running a turbo,thats a good idea!
Users browsing this forum: Ahrefs [Bot] and 13 guests
