It is currently Tue Nov 18, 2025 10:30 pm
PostPosted: Fri Oct 07, 2011 12:56 am
I'm working on a tight fit turbo header with a new turbo that's a water/oil cooled bearing housing and I'm wondering how to hook the water Inlet and return lines up I was thinking I could run the Inlet and return off the water pump lines and bypass the heater core how is everybody else running there lines?
Aaron
http://youtu.be/2Y4i4UOLiSA
http://www.forabodiesonly.com/mopar/sho ... p?t=126611
PostPosted: Fri Oct 07, 2011 4:02 am
I believe that is how it's done. Could leave htr core in line too as that will do nothing but help cooling.
PostPosted: Wed Oct 12, 2011 7:01 pm
Thanks Lou that's how I thought it was done and I didn't think about running it thru the heater core
Thanks Aaron
PostPosted: Thu Oct 13, 2011 8:27 am
Yep, used heater core lines on the Mitsu turbo I used to have. (The GT40 going in there is purely oil cooled.)
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
