It is currently Tue Nov 18, 2025 12:05 pm
PostPosted: Tue Oct 25, 2011 7:37 pm
whats going on guys,
Where would be the best place to drill and tap on my cliffy 4bbl for my vacuum/ boost gauge ?? I saw shaker did his on the side ( towards the driverside fender dead center below the carb, would that be a good spot ??
-Mike
I am the Guardian, I hate helos, everything leaks.......
PostPosted: Tue Oct 25, 2011 8:53 pm
i have my boost gauge on the start of the #6 runner and the water injection switch signal on the start of #1 runner.
PostPosted: Wed Oct 26, 2011 7:12 pm
my cliff intake has a threaded hole which i have a big cluster of vac ports coming from kinda lookd like a big bolt with octupus arms coming off it. I pull my bov signal my boost gauge signal from there. it's located just below the carb plate on the driver side between the coolant line barbs on mine.
Kev
PostPosted: Sat Nov 05, 2011 11:31 am
ok well dumb dumb me forgot i had a nipple that screws into the 1" alum carb spacer, could have used that damn lol, and way got the intake tapped in the center below the carb, now should i use the plastic line or should i upgrade to the copper line ??
-Mike
