It is currently Wed Nov 19, 2025 10:29 pm
PostPosted: Wed Nov 23, 2011 9:17 am
Does anyone know how large of a spring the head can handle and what the installed height is ?
PostPosted: Wed Nov 23, 2011 10:26 am
1.500 OD springs.
The factory installed the stock springs at 1.700 but I have done set-ups using a 1.800 I.H. (Mopar BB valves & springs)
The taller spring really helps when using a cam with high lift.
 Post subject: New question!
PostPosted: Wed Nov 23, 2011 8:20 pm
Doc,
Does this affect the pushrod length much? I know that the taller stem might affect rocker geometry a bit, and adjusters can only be tightened or loosened so much, will this require a mock up and an adjustable pushrod measuring tool as well?
Just curious,
PostPosted: Thu Nov 24, 2011 5:47 am
1.500 OD springs.
That really helps...Thanks Doug & Happy Thanksgiving all !!!
