It is currently Mon Nov 17, 2025 6:29 pm
Post new topic  Reply to topic  [ 43 posts ]  Go to page 1 2 3 Next
PostPosted: Wed Jan 04, 2012 3:21 am
Hey.
I just got this Plymouth Valiant ´75 and it´s my first american car :lol:
I have read a lot on this page about the engine but can´t seem to id it.
The carb is a 2bbl Carter 2681 i belive ... (pic.)
The engine is from a Plymouth Volare from 81´, i been told.
The engine sounds very good but the carb is the problem!
The question is would the weber 38/38 be any good for my engine? Have read and lot about the 32/36 is to small for the 225.
Hope you understand it all ;-)
PS. Thanks for this page - is gold !!!
https://picasaweb.google.com/1093386251 ... 3/SlantSix
Hope the link works ...
Proud owner of a Plymouth Valiant ´75
Last edited by Valiant ´75 (DK) on Wed Jan 04, 2012 8:14 am, edited 4 times in total.
PostPosted: Wed Jan 04, 2012 4:13 am
If you have a pic that would help but i'm fairly certain the carb is a
Carter BBD. If you have problems with it; probably because of the throttle shaft bushings.
I've heard good things about Webers, never used one myself.
'73 Scamp (the girlfriend): 225ci super/6 2BBL conversion (Almost done!)
'90 Subaru, wagon (the wife): H4-cyl 2.2L
1977 Mercedes-Benz 300D, 5cyl diesel(For sale!)
PostPosted: Wed Jan 04, 2012 5:46 am
Welcome. Regarding the Webers, I have run both the 38 and the 32/36 on my van and I prefer the 32/36 for my intended use. in the past, I have also run the 32/36 on a Volare with good results. Adapting the Weber requires some cost and/or some fabrication though. Good luck with your slant.
1985 Dodge B250 Van
PostPosted: Wed Jan 04, 2012 6:55 am
Ok sounds good but can the 38 work on my 225? Don´t mind the work fitting the weber but where too buy one that fits? Can this one my car ?
http://www.ebay.com/itm/300206316037?_t ... IT&vxp=mtr
Maybe somebody got a used complete set weber/holley?
Thanks for the welcome ;-)
PostPosted: Wed Jan 04, 2012 6:57 am
There is a link to some engine/carb pic.
PostPosted: Wed Jan 04, 2012 7:42 am
The 38 will work fine. As I recall, I needed to buy adapters for the manifold, a trans kickdown cable, fabricated a linkage bracket, etc. Here are some links that might be helpful. I've purchased from both.
http://www.redlineweber.com/
http://www.webercarbsdirect.com/
1985 Dodge B250 Van
PostPosted: Wed Jan 04, 2012 2:36 pm
The 2681 is not the carb model number. Only way to indentify that is by a metal tag.
I doesn't look like a super six carb. I think it is off a 318 V8. The slant units will have a bent PCV tube for the PCV hose. V8's are straight. The flat spot at the top of the choke is thinner looking on a V8 BBD.
Watch the BBD video that is available via this web site.
'72 Duster 198 stock cam, 3:23's Hookers on jack stands for 8 years in the driveway
'79 Maxivan 360 Offy Qjet Comp RV cam/rusting in the driveway.
93 D350 160HP Cummins Auto :-( Dually Clubcab needs a injector pump
2005 Golden Couch Buick
PostPosted: Wed Jan 04, 2012 3:56 pm
"I just got this Plymouth Valiant ´75 and it´s my first american car" Laughing
"I have read a lot on this page about the engine but can´t seem to id it."
Should be a forged crank 225.
Dave
1972 d-100 parts truck
PostPosted: Wed Jan 04, 2012 4:53 pm
The V8 BBD should also have a couple holes in the throttle plate that the sl6 BBD don't have. The V8's need more air for idle than the /6. From what I know about this sl6's either run fine or horrible due to these holes.
PostPosted: Wed Jan 04, 2012 7:56 pm
Valiant 75's carter BBD looks to have the bent PCV nipple, so I think it used to be a super6 carb- before it got hacked. That choke cable setup is just FUGLY! It would have taken alot less work to just fix it properly.
And why is there a vac hose going from the manifold port on #6 intake runner then Tee'ed into the vac advance hose?
63 Valiant Wagon
225 - 4 bbl
PostPosted: Thu Jan 05, 2012 4:10 am
That's funny, it don't don;t look hacked, at least you can't see from the complete opposite side of the engine in the pictures.
here...click me
PostPosted: Thu Jan 05, 2012 5:04 am
[quote="exoJjL".[/quote]
The V8 BBD should also have a couple holes in the throttle plate that the sl6 BBD don't have. The V8's need more air for idle than the /6. From what I know about this sl6's either run fine or horrible due to these holes.[/quote]
I wouldn't bet the farm on the holes comment. Where the idle screws are in the base things are different. More restriction on the slants. 2 square holes.
PostPosted: Thu Jan 05, 2012 5:23 am
Why Laughing ???? Iám danish ;-)
I have had about 40 European cars and this is my first american car.
Almost all other dane that is driving american has a V8 but I like the slant six ;-)
Can anybody tell me anything about the engine?
What carb should I juse on my car? Weber or Holley? The Carter is garbage and it will be changed.
I don´t know who fixed the carter on the car but I want a new one ;-)
Last edited by Valiant ´75 (DK) on Thu Jan 05, 2012 5:37 am, edited 1 time in total.
PostPosted: Thu Jan 05, 2012 5:25 am
[quote="exoJjL".
I wouldn't bet the farm on the holes comment. Where the idle screws are in the base things are different. More restriction on the slants. 2 square holes.[/quote]
I have no problem with citing a source:
http://www.slantsix.org/articles/supersix/article.htm
I am also running a sl6 BBD over earlier V8 BBD for prescribed reason.
So how about that farm?
PostPosted: Thu Jan 05, 2012 5:46 am
Do know anything about the vac hose setup. I got the car one week ago and it does not run quite well. That´s why I want a new carb but maybe there is something else wrong ??
Users browsing this forum: Ahrefs [Bot] and 21 guests
