It is currently Wed Nov 19, 2025 12:57 am
Post new topic  Reply to topic  [ 165 posts ]  Go to page 1 2 3 4 511 Next
 Post subject: Rear Gear Oil
PostPosted: Mon Jan 30, 2012 1:39 pm
How many of you racers run 40 or 50 wt engine oil in the rear end of your drag car instead of 85W140 Hypoid stuff?
I have talked to romeo about this But I haven't tried it yet.. I don't want to blow anything up.. or shear gears or anything dumb like that.
I have heard stories about some guys doing this...
I was just curious..
Thoughts / discussions welcome
PostPosted: Mon Jan 30, 2012 1:46 pm
No hypoid additives, I wouldn't risk it............
PostPosted: Mon Jan 30, 2012 1:49 pm
There are many engineered "lite" gear oils made for this application...
Redline has a few different ones.
http://www.race-mart.com/Synthetic-Shoc ... 12711.html
PostPosted: Mon Jan 30, 2012 2:56 pm
Spool or SG?
I have seen quite a few people run ATF when they have a spool.
Not sure I would go that thin, but it works for them.
PostPosted: Mon Jan 30, 2012 3:03 pm
A lot of the blown alcohol bogger cars run white grease......specially with ratios over 4.88
PostPosted: Mon Jan 30, 2012 3:52 pm
Say,
The 50 wt crankcase oil is in the same viscosity range as the 90 wt gear oil. They rate them differently to get the different #'s. Confusing but true. Running the 75w90 would be a good choice. I see Redline's Superlite is just a 75w90. I've heard the same stories about ATF in rear-ends but never tried it. The ATF (10-20wt) would fall into the 75-80 wt class in gear oils. Good luck
Later,
Ryan
10.74 @ 127.47 mph 1320 ft
6.65 @ 107.80 mph 660 ft
http://www.youtube.com/c/turbo66valiant
Follow on Instagram - turbo66valiant
Facebook - https://www.facebook.com/ryan.peterson.737
PostPosted: Mon Jan 30, 2012 6:00 pm
SSRN National Champion
this is one of my secrets of a race car that can stay dialed in. My car with the stock engine i used ------ in the rearend racers said you can not do this. I can do what i want to in my race car. With the Bruner race engine I use ------- in the rear end . It is not so much I would tell but it is about the performance and dependable that I have had and that is what it is worth. I can tell you what I have used and what i now use at the Banquit. Thanks Ron :D
It Aint Over Until I Win
PostPosted: Mon Jan 30, 2012 6:04 pm
Not everyone can use chewin tobacco in their diff Ron.....it will mess yer Sure-Grip.
PostPosted: Mon Jan 30, 2012 6:07 pm
Spool or SG?
I bought a Duster in the mid '80s that had ATF in the diff along with 6.17 gears.
Slant Cecil
PostPosted: Mon Jan 30, 2012 6:09 pm
wrong answer Sandy as usual but it could be Bagel frosting Ron :D
PostPosted: Tue Jan 31, 2012 4:05 am
Spool or SG?
In My case this would be with a spool.
No sure grip or clutches of any kind.
I want to try to achieve some oil / weight / viscosity between cold runs and hot ones..
THe cold runs the car is a bit slower so If at a race the car sits looooong between rounds or is just cold it slows down sometimes a tenth. :-(
PostPosted: Tue Jan 31, 2012 11:14 am
I'm gonna hold you to that Ron. I wanna do what you do too! :wink:
PostPosted: Tue Jan 31, 2012 11:17 am
I've seen many of the faster cars (You know, the Big Dogs) running their cars up on jack stands before a pass to warm up the trans and rear...
PostPosted: Tue Jan 31, 2012 1:47 pm
Yes I have done this and it does help, but it's not the same as a 105 mph blast down the 1/4 Mile At times rear gear temps after a run are 105* and then quickly cooll back to 85-60* running on a jack somtimes gets it back up to 90*..
PostPosted: Tue Jan 31, 2012 2:45 pm
Drink heavily and pass out early? :lol: :lol: :lol: :lol:
Greg, it does help consistency to make a long trip to staging after you sit for awhile. If you get held up in staging it's best to dial down a little.
