It is currently Tue Nov 18, 2025 5:45 pm
 Post subject: is france in the house?
PostPosted: Sun Oct 05, 2003 10:42 am
dependent kinase inhibitor p27 is associated of FGF2 implanted (at the time of coronary the negatively charged DNA molecules
Joe, if it's any consolation, the first time is always the worst If you did this on a monthly basis, not only would there be less hair growth month by month, but the hair would be thinner so it would
I suspect that it is a case of there no longer being much offered in that caliber Winchester no longer chambers it, but you can find them on the used market I'm a M70 fan, so I'd look at GunsAmeri
(Think a chicken Caesar salad is perfect for your diet? Think 1 tablespoon your favorite dry tea portions. Restaurants in Europe serve portions 30 to 40 percent
66 valiant basket case
what's H20? i own a 73 bug...
PostPosted: Sun Oct 05, 2003 1:25 pm
Ok lets start in the rear. the best way I have found is to flip over the front spring hanger. makes it as low as Id ever want to go even with SS springs. You can also use lowering blocks if you just want a small drop.
On the front depending on how far you want to go it can be a simple as adjusting the torsion bars. The problem is this lowers the spring rate of the torsion bars. You could use stiffer bars to offset this. Now the best way is dropped spindles. ChecK out http://www.fatmanfab.com/ . Not sure if they are listed on their website but they do make them. They are however for later disc brakes and the bigger ball joint, If you havent swapped out your drums yet you will have to now.
________
Volcano Digital Vaporizer
________
Smoking Kills
PostPosted: Sun Oct 05, 2003 7:28 pm
Rear sounds easy enough. I looked at the spindles..approx. 435 bucks!!! :shock: :shock:
Adjusting the torsion bars should not be that hard, if its anything like a VW front end. Sounds even better if you can offset it with stiffer bars.
Where could I buy stiffer bars?
PostPosted: Sun Oct 05, 2003 7:38 pm
Stiffer bars are an MP product, $125ish a pair at summit last I recall.
 Post subject: Torsion bars, etc.
PostPosted: Mon Oct 06, 2003 3:34 pm
One key concern about lowering is, of course, that the car doesn't bottom out. That's why I do not favor removing leaves from the springs. It's best to, if possible, stiffen the suspension when you lower it.
I've heard the claim that cranking the torsion bars lower reduces stiffness, but I'm not sure what the extent of this is. It is likely to increase bottoming out with less travel even if the spring rate is the same. Does anyone have a chart of how much lowering can decrease the effective spring rate? I remember someone from Bigblockdart.com posting some interesting geometry calculations a while back...
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
 Post subject: flipping front hangers
PostPosted: Tue Oct 07, 2003 5:38 pm
i think if you flip the front hangers you'll need to redrill the bolt holes on the subframe, they don't make a perfect square, at least on my '64 valiant... i am using 1" lowering blocks from AutoDrone, about $25 bucks, use the Mopar U bolts though, the ones that come in the lowering kit suck!
for the front, try the .890 bars and set to desired height...
PostPosted: Tue Oct 07, 2003 5:45 pm
[quote="Thropar"]i think if you flip the front hangers you'll need to redrill the bolt holes on the subframe, they don't make a perfect square, at least on my '64 valiant... quote]
You are correct. Just elongate the holes a little with a die grinder. Takes like 10 minutes.
________
Honda Cr125R
________
SILVER SURFER VAPORIZER
PostPosted: Thu Oct 09, 2003 10:12 am
I sell A body hangers that have the eye bolt hole moved up 1 inch. This will lower the car a little more than 1 inch at the rocker panel.
Go to www.arengineering.com for more details.
