It is currently Tue Nov 18, 2025 4:55 am
Post new topic  Reply to topic  [ 29 posts ]  Go to page 1 2 Next
PostPosted: Tue Apr 24, 2012 6:04 pm
Holy wah! I just found the correct slot-lock end nuts and a whackload of additional options in steel, stainless, and brass, at McMaster-Carr. You can get plain or fancy. And lookit, manifold studs with a drive hex end!
PostPosted: Tue Apr 24, 2012 6:23 pm
Thanks, Dan!
obliquely-inclined state of mind
PostPosted: Tue Apr 24, 2012 6:24 pm
Holy wah! I just found the correct slot-lock end nuts and a whackload of additional options in steel, stainless, and brass, at McMaster-Carr. Select 5/16-24 in the size list and the options will be displayed. (I'm liking the look of those 12-point items, for example).
WOW!!! and if you dig you can findthese What a great find Dan... Page will be book marked for future reference.
MRO....
Cheap, Fast, Reliable.... Pick 2...
PostPosted: Tue Apr 24, 2012 6:48 pm
McMaster-Carr is one great toy store for men. :D
PostPosted: Tue Apr 24, 2012 7:55 pm
Sweet! Part number 94358A270 appears to be an ideal high-strength steel manifold-to-head stud with a drive hex in the end for E-Z installation.
Now all we need is new butterfly washers. Image
PostPosted: Tue Apr 24, 2012 10:50 pm
Sure love it when the smart people do the work of finding parts I will be needing when I tear my 66 valiant's engine apart to clean and rebuild it. Thanks a bunch for this info! 8)
PostPosted: Wed Apr 25, 2012 9:18 am
I really love it when a community of like-minded people help each other out... :D :wink:
PostPosted: Thu Apr 26, 2012 1:42 am
The McMaster description of how these work is interesting: Also known as Flexloc nuts, they have a slotted top that expands when the nuts are tightened—locking them in place. This explains their usage in this application: Chrysler wanted to limit clamping force on the two end ears of the exhaust manifold, so they used these nuts to make 10 lb·ft arrive "sooner" on the torque wrench, without binding the end ears so they can't expand and contract.
PostPosted: Thu Apr 26, 2012 6:22 am
Maybe make a sticky out of this thread, or put it in the FAQ page?
MRO....
PostPosted: Thu Apr 26, 2012 9:16 am
I'm thinkin' it's time to update the manifold installation article to include new gasket and hardware info.
PostPosted: Thu Apr 26, 2012 9:45 am
I’m getting ready to order studs and nuts for manifold swap here soon.
Are these the correct parts I should order?
1 package of 99638A300 and 13 of the 94358A270 studs.
What else should I order that should be replaced? (Part numbers please)
Also I want to replace the 3 intake to exhaust manifold bolts does anyone have specs on these?
Thanks
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
PostPosted: Thu Apr 26, 2012 7:04 pm
The McMaster description of how these work is interesting: Also known as Flexloc nuts, they have a slotted top that expands when the nuts are tightened—locking them in place (…). This explains the apparent weirdness of the correct installation being with the conical/slotted side of the nut facing out, not cupping into the round end washers. It looks to me as if Chrysler wanted to limit clamping force on the two end ears of the exhaust manifold, so they used these nuts to make 10 lb·ft arrive "sooner" on the torque wrench, without binding the end ears so they can't expand and contract.
I could swear I've heard that before somewhere... Maybe it was HERE :lol:
PostPosted: Sat May 05, 2012 9:19 am
Thanks Dan! I ordered some last week after seeing your great find. They have just been installed and I gotta say...that hex drive on the top was awesome for the install! I'm hoping the high heat Permatex thread locker was the right way to seal the studs to prevent water leaking from the head water jackets.? Maybe I should have asked this prior to installing them.
Slant On!
1968 Coronet
 Post subject: Manifold studs and nuts
PostPosted: Wed May 09, 2012 2:13 pm
Wow, yes, extra thanks to finding the McMaster Carr site.
So, I've been out of this for some time, does this take care of all the studs and nuts (not the butterfly washers of course) for both the intake and exhaust manifold?
What size are the bolts that mount the intake to the exhaust manifold heat riser? DD says they get brittle over time, should be replaced. I'm switching to Dutra Duals and a new intake, so I should consider the stud/nut changes now...
thanks,
'67 Dart 270
PostPosted: Wed May 09, 2012 4:10 pm
Car Model: Road Runner
Great find Dan. I'm really digging the studs myself.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 16 guests
