It is currently Tue Nov 18, 2025 9:48 am
 Post subject: Carter AFB J7 9400 S
PostPosted: Sun Mar 18, 2012 6:45 pm
Does anyone know what this 4 barrel carburetor was originally used on? It's a 400 CFM Carter AFB square bore. I am wondering if it would be a good candidate for a Turbo blow through Slant 6 and how much HP it would support? Just need a carb that can make @250-275HP...Any/all help appreciated!
PostPosted: Sun Mar 18, 2012 6:56 pm
A 9400 is an aftermarket performance carburetor not intended for any given engine. It should work just like any other AFB when boosted.
 Post subject: .
PostPosted: Wed May 16, 2012 6:07 pm
Two things might be a problem with a blow-through AFB. #1, The hollow brass floats might colapse under boost,I had this problem with a BBD. #2, without an air box around the carb, boost pressure might force raw fuel past the accel pump rod were it goes into the carb.
