It is currently Wed Nov 19, 2025 8:46 pm
 Post subject: Musing on a new project
PostPosted: Fri Jun 01, 2012 4:19 pm
Am contemplating a 170 build with a 3.8 Buick supercharger with a Quadrajet carb, I have a 5.38 rear axle, an overdrive 4 speed trans, would be installing the 5/16 oversize valves and installing longer rods with 2.5 turbo pistons, six into one header. This going into a uni-body built t-bucket so itll be very light, my question is, would a 75' style cam be appropriate and what rod to use to achieve high 7 to 8.5 compression ratio.
Advise should be taken as ongoing, that way, when you get to realizing what you are doing you can include yourself.
PostPosted: Fri Jun 01, 2012 6:06 pm
For a 170, just use stock crank, rods. I would use a forged piston of stock specs. The compression ratio should be about 8 to 1. The Buick turbo MIGHT be a little large for a 170.
PostPosted: Fri Jun 01, 2012 7:45 pm
Sounds good; Ill plan on doing up the crank, shot peen rods and blueprint ect. I was thinking blower instead of turbo, besides going to a carb shop is there much in the way of special mods?
I read about the .078 hole in oil pump on the crank scraper website, how bout a blower cam?
PostPosted: Fri Jun 01, 2012 10:50 pm
Car Model: 64 Valiant
[/quote]
[/quote]
Yep, it depends if it going to be blow-thru or draw-thru!
PostPosted: Sat Jun 02, 2012 6:14 am
[/quote]
Yep, it depends if it going to be blow-thru or draw-thru![/quote]
Draw through, I read that forced air engines like duel profile cams also, my plan is to use the last three gears of the o.d. 4 spd. with the low axle, not concerned about freeway, and use the engine with mild boost but build it very solid, nitride, shot peen, cryogenic dip etc.
