It is currently Wed Nov 19, 2025 8:43 pm
 Post subject: What to do first?
PostPosted: Fri Oct 31, 2003 1:33 pm
Over the last few months I have been noticing more and more a bit of viberation on my 75 Swinger when I brake, I checked the brake pads (Front Disk Brakes) they seem to be ok. Seems like I remember an old VW I had started having that problem and it was the tie rod ends.
I intend to replace, tie rod ends, ball joints and my idler arm all within the next couple of months, but my question is what is the most likley thing that could cause this so I can replace it first.
Thanks
JB
PostPosted: Fri Oct 31, 2003 1:45 pm
Sounds to me like you have warped rotors. This will cause anything from the vibration to a pulsating feeling in your braking foot. You can either replace the rotors or get them turned. I hope this helps-Josh
Hellbent Rods & Custom fabs
