It is currently Thu Nov 20, 2025 12:08 am
 Post subject: Intercooler flow
PostPosted: Fri Mar 29, 2013 9:59 am
Still very much a newbie here and could not find any info in the FAQ's section. What are the best intercoolers to use? I know the older Toyota's flow pretty poorly. Can anyone recommend some efficient ones? Thanks for taking the time to teach the new students.
PostPosted: Sat Mar 30, 2013 8:54 pm
Punch intercooler into your search engine should take you to some web sites that sell intercoolers & install kits, got mine from Treadstone performance out of Fla. it's a quality peice , I think it was around $450, with install kit, clamps, special silicone connectors I was over $600 It's the TRV250, the TRV125 is $200 less and would have done the job but
mounting would have been a problem on my carImage
PostPosted: Sat Mar 30, 2013 9:36 pm
don't forget to check bone yards with diesel trucks, you can find some killer deals like this gem for a mere $12 :) came off a flip cab mitsubishi core size is 19.5" wide 8.5" tall 2" thick core 28" at its widest points
PostPosted: Sat Mar 30, 2013 10:01 pm
Isuzu, GMCs, Ivecos will all have intercoolers like that, and should flow enough, in my area the only truck junk yard won't let you go out and pick through there yard, if you have a yard that will, you can probably save a few hundred if you can find one that will mount & plumb up in your application.
PostPosted: Mon Apr 01, 2013 5:55 am
Thanks a bunch, everyone. Off to the boneyards to scavenge through the bigger trucks.
