It is currently Tue Nov 18, 2025 3:10 pm
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Thu Apr 18, 2013 7:12 pm
Well With a Stock depth 904 Pan wit would most likely be fine.
I have an A&A Deep 904 Pan on there and I think it's about 2" Deeper than stock.
I dinged in the Pan Quite a but With a Body Hammer on the End of the Airchisel and Hacked quite a bit off the Flange.
Still had Clearance / Rubbing Issues - But Made 3 passes on it with a piece of old Radiator Hose insulating the Headers from the trans Pan.
Car went 3-4 Tenths slower- Reinstalled the Old Mopar 6 into 1's
PostPosted: Fri Apr 19, 2013 2:52 am
Good to know on the headers. I just mocked mine up and there is bigtime interference with the OD bellhousing from the front 3 tube exit. I cut the beat up old flange off and will try to refab something around the BH, then cut a little off the lower left corner of the BH.
Amazing how well those 6X1s are working. Experimentation is the only way to know.
