It is currently Tue Nov 18, 2025 5:41 am
PostPosted: Wed Apr 10, 2013 12:47 pm
Just trying to learn a little more on boosting a slanty. Looking to find out a little more about O-ringing a block for boost. When you o-ring how much bigger is the diameter of the O-ring in relation to the bore? Another thing is O-ring wire size. The only thing that I have read here is using 0.041" wire. Is that a standard size. Thanks in advance. John
PostPosted: Wed May 01, 2013 12:04 am
Car Model: 64 Valiant
The diameter you bore the o-ring groove isn't really critical, but you need to make sure it is outside the bore of the gasket by a decent amount so it will fall entirely outside of it. O-ringing is also best done with a copper head gasket. Many different o-ring wire sizes are available, but .032", .041" and .062" are the most common thicknesses used. Its also common in very high boosted and nitrous engines to have a matching receiver groove machined in the head to mirror image the placement of the o-ring wires location on the deck surface.
PostPosted: Wed May 01, 2013 5:59 am
Isky rents a tool and provides wire for the do-it-yourselfers.
11.02 @ 120.56
Chassis dyno
 Post subject: Thanks
PostPosted: Thu May 02, 2013 11:03 am
Thanks for the info.
