It is currently Tue Nov 18, 2025 7:16 am
 Post subject: Sealed Power Pistons
PostPosted: Sat Jun 08, 2013 12:15 pm
Anyone know if these will hold boost? Probably around 15 lbs, strip only car.
1965 Plymouth Belvedere II Turbo Project - SOLD
2002 Subaru OBS
1995 Lexus LS400 Race Car
PostPosted: Sun Jun 09, 2013 8:48 pm
Noone? I'm about to buy them and don't really want to make a big mistake...
2002 Subaru OBS
PostPosted: Mon Jun 10, 2013 12:18 pm
I've done an extensive FAQ in the boost section that has plenty of builds to reference. More than one build was done w stock pistons, shaker comes to mind running like 20+ psi. Unless you just want new I'd go w stock as we know they work but that's me and I'm about to use an hx35 :shock:
225, Offenhauser, Holley 350, A833OD, 3:55, GM HEI,99 Durango starter
BOOSTED! WH1C, BIG FMIC, 10#
Operation Noble Eagle 03-05
Operation Iraqi Freedom 05-07
Operation Enduring Freedom 12- 13
PostPosted: Thu Jun 13, 2013 6:22 am
Stock 1989 silvolite 3.43" cast pistons on my 9-10 psi build (330 HP so far). 170k on motor.
PostPosted: Fri Jun 14, 2013 7:09 pm
I have seal power np244 .080, 12 to 15 psi with meth injection, 20degs timing no problems, set them up loose. called for .001 clearance, I set it at .005, top ring at .024 , second ring .018
