It is currently Tue Nov 18, 2025 10:35 pm
Post new topic  Reply to topic  [ 146 posts ]  Go to page 1 2 3 4 510 Next
 Post subject: Slant 6 turbo project
PostPosted: Mon Feb 10, 2014 6:32 am
Car Model: Valiant -66 turbo
Hello friends, beginner here.
Want to show my slant 6 project. Its converted to fuel injection, and e85.
I am using a Garrett gt3076r, head is ported and have oversize valves 1.70-1.44.
cam is Howard 220 @ 0.50 0.473 lift LS 110
Going to use stand alone system for fuel and ignition.
Its not started , have a small rest now . Waiting for money to buy the missing parts.
But its close now...
Thomas S :D
PostPosted: Mon Feb 10, 2014 10:21 am
Nice one :D Where is it going in?
PostPosted: Mon Feb 10, 2014 11:18 am
Hi, Its for a Valiant -66 automatic 2 door sedan 8)
Thomas S
PostPosted: Mon Feb 10, 2014 12:54 pm
More pics..
Here you can see the stock intake, transformed with 80mm. throttle body.
The fuel injector bosses are welded with 30 degree angle to the intake.
I didnt want the injectors to spray just the floor , now i hit the valve pocket . (more or less).
I found a bosch injector (pt 1040 cc.) with a 1 inch extended nose
Perfekt because of the boss angle.
Its a big injector, but i run this engine on e 85, and i think they are easy to
Control also at idle speeds
PostPosted: Mon Feb 10, 2014 1:14 pm
Support for turbo
Its not welded to the exhaust, (stock exhaust with welded extension for wastegate Connection) it just support with a slightly press to hold the weight of turbo.
I think this will minimise the risk for crackings :idea:
PostPosted: Thu Feb 13, 2014 7:42 am
NICE!! That is a very clean setup. Does the engine management have O2 sensors? How are you triggering the coil packs?
KAKAWWWWWWWWWWWWWWW!!!!
PostPosted: Thu Feb 13, 2014 11:38 am
Hi, thank you
Now i have weld in O2 bung in the downpipe and also got a AEM afr gauge.
Im going to run this whith a engine management system named Civinco.
They are using some kind of "credit" card to store your fuel- ignition map
And its easy to change map, even when the car is running.
In- out- finish. From grannys car to race car in one second..... :D
Im triggering from a 60-2 missing tooth wheel , at the harmonic balancer.
PostPosted: Thu Feb 13, 2014 11:40 am
PostPosted: Thu Feb 13, 2014 11:41 am
PostPosted: Thu Feb 13, 2014 11:42 am
PostPosted: Thu Feb 13, 2014 11:44 am
PostPosted: Thu Feb 13, 2014 11:51 am
Hoho what is hiding in this scary Cave..
maybe a slant monster...
PostPosted: Thu Feb 13, 2014 10:26 pm
Very nice work, Thomas, snyggt jobbat!
Olaf
Aspenized
PostPosted: Fri Feb 14, 2014 8:27 am
Excellent work.
Thanks for sharing.
PostPosted: Fri Feb 14, 2014 2:11 pm
Excellent work.
Thanks for sharing.
Nice to hear Greg, Its an incredible Na. slant Engine in your Ruster.
High rewing + 6K ?
Users browsing this forum: No registered users and 17 guests
