It is currently Wed Nov 19, 2025 7:42 pm
Post new topic  Reply to topic  [ 91 posts ]  Go to page Previous 13 4 5 6 7 Next
PostPosted: Mon Feb 17, 2014 12:53 pm
Dennis, I am going to call you captain negativity! :lol: :lol:
Yes I know. Yes I will likely run it just for the wow factor on the engine that goes in the car for this year. I won't be all that fast but it might as well look cool. :lol:
Pretty sure that next year at this time I will be installing another big bore motor and Jeffrey head, so the Clifford intake and long tube headers will go back on. We shall see.
Rick
PostPosted: Mon Feb 17, 2014 8:52 pm
:lol: :lol: :lol: :lol:
PostPosted: Tue Feb 18, 2014 8:45 am
Then you will find out what a horrible manifold il really is.
But you already know that, don't you. :wink:
I can Attest to that.
Anything below 65* on a cold engine is dance on the throttle city.. yay for a stick car.
If it were on a dry MPEFI System it would be more than ideal.
PostPosted: Tue Feb 18, 2014 9:18 am
Found the starters on Amazon also for $113 with no core charge and free shipping if anyone is interested.
Rick
PostPosted: Tue Feb 18, 2014 9:23 am
At least it looks cool right!
Kev
PostPosted: Tue Feb 18, 2014 11:16 am
Rick
I am interested in how much they weigh?
Do I need to come out there with my scale and find out myself?
PostPosted: Tue Feb 18, 2014 1:38 pm
Ooops I forgot. Headed to the garage. Only have a bathroom scale.
PostPosted: Tue Feb 18, 2014 2:06 pm
Both the original mini starter and the new "super mini" weighed 7 lbs. That should be pretty close because the UPS label on the box the starter came in said it weighed 7.9 lbs. So there is not really a weight savings, only a space savings. :lol:
Rick
PostPosted: Tue Feb 18, 2014 3:05 pm
Just one less doughnut guys !!!! :wink:
PostPosted: Tue Feb 18, 2014 6:42 pm
Rick
thanks.. I don't need to spend that much for maybe 9#. I can cut that out of the drivers door .
thanks for yor efforts! much appreciated.
PostPosted: Wed Feb 19, 2014 6:15 am
Greg,
Aren't you already running a mini starter? Where is the 9 lbs difference..? :?
PostPosted: Wed Feb 19, 2014 1:02 pm
Greg,
Oops
Typed wrong.
I do have a mini starter.
I meant 0.9..
Damn decimal went in the wrong place on the eariler post.
PostPosted: Wed Feb 19, 2014 2:26 pm
Poser
Hang it on the wall a revel in the fact that you own one. You will be happier in the long run. :lol:
Might make an attractive clock. The works would fit nicely where the carb sits.
PostPosted: Sun Feb 23, 2014 7:14 am
That is soooo cool! U have an amazing score! I could have bout a "set" just like this at mopar nats 93 in colombus for 500. Seemed high at the time... Lol. Thanx for the pics[/u]
Mopar or nocar!!!
PostPosted: Sat Jul 12, 2014 6:54 am
Car Model: 1961 Dodge Lancer 770, 1938 Dodge Business Coupe
It took me more time than I care to admit to figure out how to NOT
Cut a hold in my hood and fit the hyperpak.
What I did was opened up the the plenum area and inserted a phenolic spacer that I machined down. I used a 1/2 inch spacer from jegs and cut it down to about an 1/8 inch thick. The center 4 hole section sets down into the manifold 3/8 of an inch. That is about the thickness of the mounting are of the manifold. I drilled and tapped the manifold to accept the carb studs directly.
I then used a low profile plenum from spectre performance that flows 600 CFM with a 4 inch tube opening. I did have to cut one rib, but if done right it looks good. A four door car street vehicle looks silly with a hole in the hood.
I will try to post some picture soon.
61' Lancer 4 door shaved .200 ported polished,Balanced, Hyper-pak ,Headers,dual 2.5", 4 speed, 3.23 posi 8 3/4",205 70
