It is currently Mon Nov 17, 2025 10:38 pm
Post new topic  Reply to topic  [ 361 posts ]  Go to page Previous 13 4 5 6 725 Next
PostPosted: Sun Feb 01, 2015 6:42 pm
Wow, that looks pretty damn sweet! I wish I had the know-how and equipment to make my own EFI turbo setup...but there's nothing wrong with a carb'd turbo slant. I'm keeping an eye on this project! Keep up the good work brotha!
-Brodie
1977 Dodge D100 stepside, slant six/3 on the tree
2002 Chrysler 300M Special (daily driver)
PostPosted: Fri Feb 06, 2015 11:33 am
With the fabrication finally done on the intake manifold and plenum It's ready to seal up. A quick tally comes up with about 8 feet of weld bead in this thing. You can bet there are at least a couple of places where some porosity in a weld would create a vacuum leak. I could figure out a way to pressure test it and grind/re-weld whatever turns up. Instead I decided to coat the inside with some epoxy I got from Caswell. I gave it 2 coats. The second coat went on nice and thick.
--> The Diesel Corvette <--
PostPosted: Fri Feb 06, 2015 12:03 pm
Car Model: 64 Valiant
Looks like your close to getting it fired up. Looks good!
PostPosted: Fri Feb 06, 2015 12:17 pm
How well does that epoxy stick to the shiny aluminum? The thought of it flaking loose makes me cringe. I would have high temp powder coated the outside
PostPosted: Fri Feb 06, 2015 12:51 pm
Well... the block, crank, head, etc. are still at the machine shop.
But, yeah, not that far away from hanging the turbo and manifold on the old stock motor that is still in the truck.
PostPosted: Fri Feb 06, 2015 12:55 pm
I etched it with POR15 metal prep. So it should stick all right. I've even used this particular stuff on the inside of polyethylene motorcycle tanks. Nothing sticks to those - except this Caswell epoxy.
PostPosted: Fri Feb 06, 2015 9:10 pm
I made a bad mistake and learned something new.
Ha ha... those 2 things go together don't they?
So I welded all those pipe thread bungs into the plenum for various things that will have to plug into them. I had some nice brass plugs that I put in the holes then I submerged the whole thing in a bucket of etching solution. Well the solution wicked into the threads and jammed all the brass plugs in all the threaded holes. I had to drill all 6 of those suckers out. No, it was not the epoxy. I could see the evidence of corrosion on the remains of the threads.
It's all good now. The plugs are drilled out and the holes have been re-tapped. But I didn't need to cause myself an extra couple hours of work.
PostPosted: Thu Feb 26, 2015 8:39 am
A couple new pix
PostPosted: Fri Feb 27, 2015 12:08 am
Car Model: Valiant -66 turbo
Very cool look of that intake!!
The combination with stock runners and your own design plenum,
and the colour... Kawasaki green?
:D
Thomas
PostPosted: Fri Feb 27, 2015 4:53 pm
The place I had to cut the exhaust manifold to retain the divider didn't put the turbo quite where it needed to be so I fabricated and extension to move the turbo out and up. The extension is also divided to keep the exhaust pulses separated going into the divided turbine housing.
... Kawasaki green?
Hey Thomas, Rustoleum calls it Grabber Green but it is pretty close Kawasaki.
PostPosted: Sat Feb 28, 2015 12:55 pm
So... It's going in the Vette, right :twisted: :lol:
Lookin' good!
PostPosted: Sat Feb 28, 2015 1:36 pm
Well, it's not going in that Vette but possibly in a slightly newer C4 if I can find the right deal.
The Vette in the background is motivated by a GMC 6.5 diesel with a big turbo and a cranked up injection pump. :shock:
PostPosted: Sat Feb 28, 2015 2:16 pm
Here's a write-up of the Diesel Corvette build
https://www.dieselplace.com/threads/die ... ed.800234/
PostPosted: Sat Feb 28, 2015 5:49 pm
Today I worked on additional mock-up stuff. Re-shaped the dipstick tube.
Since I will temporarily run i a draw through on the one barrel carb I fabbed up an intake to mount the carb to the turbo.
EDIT: I've decided I'm not going to do this. Not even for test running
PostPosted: Mon Mar 09, 2015 9:58 pm
A little more intake plumbing done.
