It is currently Tue Nov 18, 2025 2:58 pm
Post new topic  Reply to topic  [ 143 posts ]  Go to page Previous 1 2 3 4 5 610 Next
PostPosted: Tue Aug 04, 2015 8:04 pm
greg they did that this pass winter, hope to get a full 1/8 mile pass in this summer, haven`t put the spool or aftermarket axles in yet.
PostPosted: Thu Sep 10, 2015 3:19 pm
will the full 1/8 mile was finished for the summit sonic rush tour last weekend. first time racing at night. car was great all Friday night and all day Saturday but sunday had electronic trouble. before that ran a best at this track with 10psi boost 7.27@93mph https://youtu.be/LPLy1XEL-Pg
PostPosted: Thu Sep 10, 2015 5:19 pm
Congrats! Livin' it up...
PostPosted: Thu Sep 10, 2015 6:52 pm
first time racing at night no lights except in gauges! https://youtu.be/GslUg2fry7A
PostPosted: Fri Sep 11, 2015 4:22 am
Sounds awesome, what rear gear? do most run stiffer gears for the 1/8th?
Nice set up, thanks for posting.
Derek
70 Duster 238'', four speed ,3:91's, 500 Elde, Hookers
68 Dart 4 dr 225, completely original
PostPosted: Fri Sep 11, 2015 6:46 am
most kept the same setup that worked at clarenville 1/4 mile track. I am running 4.56 but I am going back to 4.30 which I ran my fasts et at clarenville 1/4 mile track including 7.14et in the 1/8 .
PostPosted: Mon Sep 21, 2015 1:45 am
second weekend with full 1/8mile fixed the problem , it was dist breaking down, reluctor pickup coil seem to be contacting at higher rpms. made the final 4 but broke out, ran my first 7.0etImage
PostPosted: Mon Sep 21, 2015 4:07 am
Awesome!
I am only about .7 from running 7's in th 1/8th myself!
PostPosted: Mon Sep 21, 2015 3:19 pm
that great greg, first time since I did the fresh head and o-ring / studded the block with copper head gasket. ran 1to1 pulley 15 psi 20degs adv with the new 4.30 gears and strange axles. leaned the carbs down to 69 and 68 jet really clean her up.
PostPosted: Sun Oct 11, 2015 5:01 pm
just back from the track got rained out on the last race weekend of the year, made second round and broke out. 7.02@96mph on a 7.08 dial. almost got my 6.9et/ 10.9 et pass, maybe next year. https://youtu.be/bhFyWNfjvIs
PostPosted: Mon Oct 12, 2015 3:59 am
Hey Terry those videos are awesome thanks for sharing. That in car when the dragster shoots past is really cool.
The et will come you're right there. Great job
Derek
PostPosted: Mon Oct 12, 2015 6:14 am
thanks, yes that's Dave Anthony he has the fastest railer in eastern Canada. had the camera on the gauges seems it only hitting 14psi with the 1/1 drive , I have a 30 tooth pulley but that should put me at 19psi if everything stays together, I want to go quicker but don`t want the motor to be set on kill every run. https://youtu.be/f8aUg_tYreM
PostPosted: Wed Oct 05, 2016 6:03 am
another season over, never got my 6.9et, ran some 7.0s ets. had earily season converter troubles vibrating the car so bad that crank bolt would spit out. last couple of weekends rings started failing pressurizing base and pushing oil out front and rear gaskets, so went back to 10 psi pulley but got to run with full mix methanol 24degs timing and ran 7.13et@94mph. my best with 10psi before was 7.28et@92mph. need to fresh`in up the engine over the winter and hope for 6`s next spring. https://youtu.be/yWI1naEOU3M
Last edited by terrylittlejohn on Wed Oct 05, 2016 1:13 pm, edited 1 time in total.
PostPosted: Wed Oct 05, 2016 11:12 am
Cool runs, Terry! Good luck with rebuilding for next year...
PostPosted: Fri Oct 07, 2016 3:01 pm
thanks lou, I did realize how much I had too lean out the methanol from 2 #5 jets to 2#3 jet car seem to like it. next season was thinking I should try more timing adv before I try boost.
