It is currently Tue Nov 18, 2025 9:44 pm
PostPosted: Thu Dec 10, 2015 7:15 am
Please forgive all the questions, but I am a Big Block Mopar guy in a Slant Six world here.
Is there any advantage to using full groove main bearings on a slant? It is common to use them on the big block. At one time, you either had to get two sets or find a set of Marine bearings to do it. Now, they are easy to get. I really haven't seen this with the 225 engine.
-Matt
PostPosted: Thu Dec 10, 2015 1:08 pm
As far as I know you need to buy two sets to get the second half of the bearing.
I have spoken to a couple racers about this. Some have tried it both ways and have seen no difference in wear and failures.
Others swear that you should use full grooves.
When I spoke to Mike last, he recommended it for the two center mains and not the outer two. The two center mains feed two rods each, so they can use a little more oil on those mains.
So it has been done all different ways. I still do not know what I am going to do with my engine.
PostPosted: Thu Dec 10, 2015 2:17 pm
I have never used them. Oo, good idea about the 2 center ones to give enough oil to 2+3 and 4+5 rods, though.
PostPosted: Thu Dec 10, 2015 4:25 pm
its easier to just 0.050" X 0.050" groove the mains on the crank and run stock shells.
i have done both with modified lower shells - It gets expensive after a while to always buy 2 sets of bearings.
One Trip to the machine shop and groove is in the crank forever until you break it.
Others just use a lead in groove on the bottom shells.
PostPosted: Thu Dec 10, 2015 4:50 pm
Wouldn't grooving the crank make it weaker? I figure I could groove the bearing itself with a dremel. What's the worst that could happen?
-Matt
PostPosted: Fri Dec 11, 2015 4:49 am
I always use full groove mains. Whan I first started running slants I did have some rod bearing problems. Never had a problem when running stock eliminator, but did once I started hopping it up. At first I used two sets of bearings, and cut a new notch in the cap (never liked Mopars sugestion of filling down the tab,as it could crush the bearing if even slightly high). Now being the cheapskate I am, I cut a groove in the lower shell with a cutoff wheel in a die grinder. It is not fancy or neat, but works for me. Have not had a bearing problem since 1978.
PostPosted: Fri Dec 11, 2015 8:09 am
Well, if it is good enough for Charlie, it is good enough for me.
-Matt
PostPosted: Fri Dec 11, 2015 9:30 am
the groove is minimal only, only 0.050" X 0.050"
People with 10 Second turbo slants have done this without weakining the crank.
PostPosted: Fri Dec 11, 2015 9:31 am
Ok, good to know.
PostPosted: Fri Dec 11, 2015 1:02 pm
Car Model: 64 Valiant
You could also consider cross drilling the main journals, i've done it many times.
PostPosted: Sun Dec 13, 2015 12:50 pm
Charlie, do you tape up the bearing to keep it clean? and how do you clean up the edge left by the cut off wheel? I think you already told me but I forget!
PostPosted: Sun Dec 13, 2015 7:16 pm
I tried to run full grove mains on a cast crank and suffered major bearing failure. To this day I am not sure why. When I reassembled the engine i used the standard bearings and have not had a problem.
PostPosted: Mon Dec 14, 2015 8:30 am
The groves in the top half of the bearing and the holes in the crank are set up to send oil to the rod that needs it at that time. The lower bearing slightly cups under torque. In my opinion all that is needed is to champ her crank oil holes. I have not torn up a crank since I stopped messing with the bearings (7000 rpm every gear every pass). That said I have broken every other part of the motor.
Will
PostPosted: Mon Dec 14, 2015 12:44 pm
[quote]I have not torn up a crank since I stopped messing with the bearings (7000 rpm every gear every pass).[quote]
Very interesting Will!
PostPosted: Tue Dec 15, 2015 10:34 am
I chamfer the Crank oil holes quite a bit as well.
That helps a bunch.
Users browsing this forum: No registered users and 16 guests
