It is currently Mon Nov 17, 2025 5:03 am
 Post subject: '78 Volare daily driver
PostPosted: Sun Feb 28, 2016 9:21 am
So, the original engine is starting to smoke, as well as use copious amounts of oil. An engine swap is in my future, hopefully after the school year is over. My other job is close enough that I can walk there.
So, early style head with removable spark plug tubes, or later model head?
I have both types in my garage.
'78 Volare 225
'67 Charger 318
PostPosted: Sun Feb 28, 2016 10:25 am
Early head with tubes is lighter and has more spark plug choices, later style head is heavier and won't leak oil from the tubes. The earlier head lets you pull lifters with the head in place.
In my view is is six of one, half a dozen of the other. I would pick the head in the best shape and go with that one.
PostPosted: Sun Feb 28, 2016 8:05 pm
Thanks for the response Reed.
Both heads have been cleaned, machined, valve job, etc.
I'm kind of leaning towards the early head.
Hmm...
'78 Volare 225
'67 Charger 318
PostPosted: Sun Mar 27, 2016 7:32 pm
Okay, right now, I have a Weber 38DGES 2bbl carb on an Offy intake, with an adapter.
Its been a good carb, however, I'm been thinking about going to a simpler intake and carb combo.
I recently scored a factory super six intake, iron, with a possibly rebuildable Carter bbd.
I also have a factory aluminum 1bbl intake, with no carb.
I like the idea of having a good Carter bbd again, but I also like the potential weight savings of the 1bbl aluminum intake.
Hmm...
'78 Volare 225
'67 Charger 318
PostPosted: Mon Mar 28, 2016 2:03 pm
I'd take the Offy off your hands if you decide to ditch it. I have some core BBDs I could help sweeten the deal with.
PostPosted: Tue Mar 29, 2016 3:41 pm
Okay, I will keep that in mind. This particular Offy intake has been modified a bit; heli coil inserts, and double ended studs where the adapter bolts to. I also had it "Jet Hot" coated years ago.
I have one reman bbd in my garage, not sure of its condition.
You have first dibs Reed, if I go that way.
'78 Volare 225
'67 Charger 318
PostPosted: Tue Mar 29, 2016 4:10 pm
No worries. I am totally cheap so I am sure it will be out of my price range. But if you need a core bbd, let me know.
PostPosted: Tue Mar 29, 2016 4:46 pm
Oh, I bet we could work something out... :)
'78 Volare 225
'67 Charger 318
