It is currently Tue Nov 18, 2025 11:47 am
PostPosted: Sun Mar 13, 2016 11:44 am
What would you do with the PCV valve on a race car. Keep it, eliminate and replace with a draft tube, or header evacuation system. Is there a performance advantage to getting rid of it. I would guess there is. This will be on a brand new race motor
Rick
PostPosted: Sun Mar 13, 2016 12:47 pm
I really liked the header evac system on my bogger. It made jetting easier. It really pulls hard at WOT....something PCV cannot do.
PostPosted: Sun Mar 13, 2016 5:33 pm
No problems keeping the PCV valve, even on 'race' engines. I have never had any issues with them. They don't hurt performance any.
PostPosted: Sun Mar 13, 2016 5:53 pm
I was wondering if the blow by that it pulls into the engine hurts performance at all. I would guess it does not help.
PostPosted: Sun Mar 13, 2016 6:09 pm
I wecond Sandy's pan evac system. Will help rings seal, and you can run the carb leaner.
I have always run a PCV, but my crap was always low tech.
PostPosted: Sun Mar 13, 2016 10:14 pm
I ran an evac system into the header collectors back in the day on a V8. The only thing that I noticed was the oilly sheen was gone on the back of the car when I took it off and went with a pcv system.
PostPosted: Mon Mar 14, 2016 3:08 am
I have run PCV on every engine I have ever run, turbo included. Someday I'll try the evac system. Note that none of my stuff is very fast and most of it I drive also on the street...
PostPosted: Mon Mar 14, 2016 4:06 am
On a race only motor, with open ehaust, I would go with the evacuation system. On a street/strip engine (mufflers), a PCV Valve.
Actually threre is no reason you can't run both. The PCV system is most effective at high intake vacuum (idle thru low throttle), while the evacuation system is most effective with high velocity/low exhaust back pressure, and wide open throttle.
PostPosted: Mon Mar 14, 2016 7:58 am
A good evac system will pull enough vacuum in the crankcase to reduce windage and increase horsepower.
--> The Diesel Corvette <--
PostPosted: Mon Mar 14, 2016 9:25 am
Are any of the kits better than the other? I see some have a slot cut in the nipple that is installed in the pipe and some don't. Will one be enough or do I need to run two? Thanks
PostPosted: Mon Mar 14, 2016 10:39 am
Car Model: Toad Wagon
For my race cars I tend toward light weight solutions.
Presently looking for thinner hose clamps. :lol:
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Mon Mar 14, 2016 2:25 pm
I used just one repurposed from the gulp valves used on early 80s Chev 6....
dont know about store bought ones....
no comment on slotted nipples.....but Im not into tattoos either....
PostPosted: Mon Mar 14, 2016 9:11 pm
Back in the day, most of the commercial systems were based on Mopar breather caps, some rubber heater hose and the one way gulp valve from the GM air pump system. The starting prices were usually several hundred dollars for about $20 worth of parts.
The usual BS for"High Performance" parts. Was the power improvement worth the cost. Not really, kinda like gap less rings, sounds good in theory, for a very limited usage range. But really hard to justify in real life.
PostPosted: Tue Mar 15, 2016 7:52 am
I should have enough stuff around to put together a evac. system. Hang tight for a day so I can check.
Will
PostPosted: Tue Mar 15, 2016 12:59 pm
Ok Will thanks! I was really just asking for the new engine which will be a more serious race motor. It will not be going in until after the June race at Bristol. It sounds like it will be fine either way. But if you have the stuff just bring it to Mason Dixon in May!
Rick
Users browsing this forum: No registered users and 27 guests
