It is currently Mon Nov 17, 2025 7:28 pm
Post new topic  Reply to topic  [ 16 posts ]  Go to page Previous 1 2
PostPosted: Tue Mar 15, 2016 2:32 pm
I plan on doing a hybrid system. I will install the pan evacuation system as normal and have a PCV valve in the tube/hose between the evac breather and check valve to give me PCV at idle and low load. The other valve cover breather will be open and should, in theory, only vent crankcase vapors if the muffler is restrictive.
