It is currently Tue Nov 18, 2025 5:09 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Fri Jan 20, 2017 3:36 pm
Studs with loctite..
Also drill the bolts and run saftey wire..
I use loctite red on factory bolts too.
PostPosted: Sat Jan 21, 2017 5:22 am
With most of those holes being through holes, what keeps the studs tight? Just the lock tight?
Thanks
PostPosted: Sat Jan 21, 2017 7:12 am
A Clean application of Loctite red 271 to clean dry threads will do it.
You may not need studs on every hole as this may hinder oil pan install, but definitely them it on the side with the crank scraper.
Also clean application of red loctite on the Factory type studs will work well too!
PostPosted: Sat Jan 21, 2017 6:30 pm
Studs with nylock nuts. Some of the studs have to be put in after pan is installed.
 Post subject: Link to answers
PostPosted: Sat Jan 21, 2017 6:37 pm
I knew I had asked that question before, but my search function on here is not very good! Thanks again.
http://www.slantsix.org/forum/viewtopic ... e810d87319
Users browsing this forum: No registered users and 22 guests
