It is currently Thu Nov 20, 2025 3:52 am
 Post subject: 904 no gears
PostPosted: Sat Mar 04, 2017 12:07 pm
Please look over in my Valiant thread. Sure can use some help
http://slantsix.org/forum/viewtopic.php?p=453536#453536
PostPosted: Sun Mar 05, 2017 8:56 am
... Put in the switch for the Brake and dropped it in gear and I have no gears whatsoever. Forward or reverse! I checked the fluid level and it is full idling in nuetral. This is with a factory dipstick and tube. Shifter is moving through the gears and it only starts in Park and Nuetral.
I did have forward after I originally fired the engine and got it running. I haven't done anything else to it since then. This is the spare race transmission that Seymour had rebuilt that was a Ryan's.
So Gurus please tell me what is next to do?
Me... I would drop the pan & inspect.
If you don't see anything obvious... swap-out the valve body for a stock one & re-test.
Air pressure check the clutch packs & bands while the valve body is out.
PostPosted: Sun Mar 05, 2017 1:02 pm
i haven't scanned back far enough in the thread but did motor/trans go in together or separate? was it working before the transbrake?
the reason i ask is that one time i installed a torque converter and didn't seat it all the way in. started it up and it ran fine for awhile, but then the next time we went to move the car nothing would happen.. i ended up wiping out the pump in the trans.
did the converter go "all the way in?"
70 Plymouth Valiant 4dr
PostPosted: Mon Mar 06, 2017 1:33 pm
Responded in the other thread.
