It is currently Tue Nov 18, 2025 7:03 pm
 Post subject: New Leaf Springs
PostPosted: Fri Mar 17, 2017 7:04 am
swapping out the 7 1/4 for an 8 3/4, getting it narrowed now, axles and break rebuild kit on the way from Dr. Diff
while at it I am looking to install a new set of leaf springs
69 valiant /6, gears are 3.23 sure grip, will likely lower the gears in future
what leaf springs do folks recommend for a weekend/daily driver
espo? mancini http://www.manciniracing.com/maaexhedules1.html ? or one of the numerous other vendors?
espo is something like $360 for a six leaf spring, mancini $235
just want a decent ride down the road, thru the corners, and be enough overkill for now that if I decide to seriously upgrade the engine later that I will have things covered
thanks,
austin
PostPosted: Fri Mar 17, 2017 1:39 pm
I advise getting a 5 leaf spring. 6 is really overkill and will make your car loose/twitchy and give a hard ride. It will not handle better. Espo should be less for 5 leafs and I have heard good things but never used them. If you want an upgrade, then I believe the Hotchkis "geometry corrected" (slightly lowered and a stiffer but not too much) would be good. More expensive...
PostPosted: Fri Mar 17, 2017 3:21 pm
Cheap and easy
JR Spring from JC Whitney
PostPosted: Tue Mar 28, 2017 8:00 am
Just thought I would drop a follow up line.
I ordered a set of springs from Mancini Racing. Springs and related hardware seem just fine at this point but the customer service from Mancini Racing is somewhat skeptical.
I ordered a set of rear shackles, http://www.manciniracing.com/maraboshset.html $34.95
I received a set of rear shackles looking identical but was charged $59.95 .
Called them to inquire, and they told me that that part was no longer available. I informed them it is on their internet site for sale and that is what I had asked for and I was told these were poly eurothane .
Pretty much got the oh well sort of response, although the man did not say that specifically.
when ordering parts in future, will likely try elsewhere first.
Austin
Users browsing this forum: Google [Bot] and 18 guests
