It is currently Tue Nov 18, 2025 7:27 pm
PostPosted: Wed May 10, 2017 8:08 pm
Since I am about to hook up the lines on this Aspen on a new Firm Feel Box, I remember that the Gran Fury and Dippy cop cars had a small "u" cooler with fins near the K-member.
Does anybody run a power steering cooler, and if so what brand model?
PostPosted: Wed May 10, 2017 10:04 pm
When I transplanted the power steering from a 1978 Dodge Magnum into my 1972 B300 I kept the cooler from the Magnum. Unless one is road racing or autocrossing I wouldn't bother buying one. I'd just use synthetic ATF.
PostPosted: Sat May 13, 2017 5:26 am
Back when I rebuilt the 83 D150 I added a U shaped power steering cooler, got it from a pull a part off a late 90's Dodge Ram truck, I think it was $5.00
PostPosted: Sat May 13, 2017 11:19 am
I have the cop car style on my 'Cuda. Most newer cars that still use hydraulic steering have a cooler on them. I think they are worth the effort.
1976 Feather Duster /6 4sp
1984 W100 318 727 np241
1972 'Cuda 340 4sp
1985 D250 360 46RH
PostPosted: Sat May 13, 2017 6:49 pm
https://www.flickr.com/photos/13718356@ ... ed-public/
plumbed the cooler on the low pressure return side, the late '90's OE dodge Ram PS cooler was mounted up in front of the radiator, for the '83 I mounted it to the frame by the PS box,,
 Post subject: Ok....
PostPosted: Sat May 13, 2017 8:32 pm
Looks like I will grab a U cooler since I am waiting for a little opening in the clouds to put the idler arm, tire rods, and centerlink in place anyway....
Thank guys!
PostPosted: Wed May 30, 2018 2:33 pm
Car Model: '65 Valiant 170 T5
If you don't mind cross-pollinating later Ford pick-ups have a really nice PS cooler on the lower-left front of their core support. I'm using one for a return fuel cooler on an off-road truck. I added tube nuts and cut then flared the aluminum tubing to -6AN.
Thom
Cross-threaded is tighter than Lock-tite
PostPosted: Wed May 30, 2018 5:23 pm
Thanks for the reply, car runs fine without it so I never put one in....LOL
PostPosted: Sat Jun 09, 2018 8:40 am
Interesting discussion. Why is a PS cooler needed? I know they exist, but I figured they were for heavy duty applications like racing, construction and police vehicles, etc.
Brian
https://tinyurl.com/yynpj4v2
PostPosted: Sat Jun 09, 2018 12:02 pm
Brian
My guess is that they extend the p/s pump life for warranty reasons on late model cars.
1972 'Cuda 340 4sp
1985 D250 360 46RH
PostPosted: Sun Jun 10, 2018 12:10 am
Pretty much everything off-road related runs one. High fluid temps hurt all of the seals in the whole system. Unless fitted with hydro-boost I'm not sure that a street car requires one, but it sure can't hurt.
Thom
PostPosted: Sun Jun 10, 2018 3:52 pm
Brian
My first justification was the extra heat input to the gearbox from the sometimes very close non shielded headers, which I elected to remain non shielded, and that's a topic for another thread. :D
