It is currently Tue Nov 18, 2025 7:28 pm
PostPosted: Thu Jun 29, 2017 8:39 am
Car Model: 68 dodge dart 270 2dr
Hi any causes or issues to check- simple remedys? Front breaks and pads are fairly new...
Thank you for any feedback.
HAPPY MOTORING
 Post subject: It could be...
PostPosted: Thu Jun 29, 2017 5:30 pm
Sometimes using the Disc Brake "Quiet" RTV between the piston and back the pad helps... sometimes the pad material causes it to squeal/'sing' and you have no choice...
If it occurs more when you are in a turn, it can be that the bearings are a little loose allowing the rotor to rub against one pad or the other when it is side loaded.
