It is currently Tue Nov 18, 2025 1:03 pm
PostPosted: Sat Aug 19, 2017 2:33 am
Car Model: '69 D100
Another one of these threads... I don't quite understand the math here so bear with me. Motor is stock, 3-on-the-tree manual and I'm running 215/75/r15 tires. Planning to do about 50/50 highway/city driving with very occasional towing (most of the time the long bed has more than enough room).
It seems whatever gearing I've currently got can't be too ideal for my usage because it sounds like she's going to explode over 55, ie anytime on the highway. Suggestions? The manufacturer's plate looks like it says 3.5 but it feels like it's lower than that. Maybe it's because my tires are so small.
'69 D100, 225 SL6, A745→NP435
PostPosted: Sat Aug 19, 2017 6:51 am
I would say a 3.5 or even a 3.2 gear (if you don't do much hauling) would be a good choice for you. You might need to crawl under there, pull the cover off the rear differential, and count the teeth.
For what it is worth, my 76 D100 short bed has factory 3.9 rear gears and it does spin up high on the highway. I am running 235/75/15 tires and it has the factory 727 trans. The truck can still get up over 80 and keep up with traffic, but fuel economy is terrible and the poor little slant is turning way more RPMs than I want to see.
 Post subject: D
PostPosted: Sat Aug 19, 2017 10:04 am
D
PostPosted: Sat Aug 19, 2017 12:44 pm
If it is really that bad then you probably have a 3.91 or even a 4.10 rear gears. At this point there is no way to know what may have been put in. Just jack it up and check the ratio by spinning the driveshaft and see how many turns you get for one revolution of the rear wheel.
FWIW- my truck has 3.55's and 255/70 tires(close the same height as the 235/75) and 55 is just about the perfect cruise speed. 60 - 65 is Ok too but once you get above that then I would not want to go on any 500 mile trips! :lol:
PostPosted: Mon Aug 21, 2017 6:40 am
Like Reed said, 3.55 would be a good compromise, or if you live in a flat area, even something in the 3.2 range. I live in the mountains so a 3.55 is a good overall gear in my D100. I have an A833OD but seldom use overdrive.
PostPosted: Mon Aug 21, 2017 1:48 pm
Car Model: '69 D100
Thanks all for the recs. I live in a fairly flat area so I'm leaning toward 3.2-3.5. Would just like to have fun on the occasional highway cruise... Might need front disc brakes and AC for that as well, anyway
@Dadtruck, I got a PM about your gear and pinion.. I tried to respond but I think it's stuck in the outbox. Email me if you like, zackery@willoughby.net
PostPosted: Mon Aug 21, 2017 4:50 pm
With your tire size, you will be turning 3000 rpm's at 70 mph with 3.55 gears. 3.21's will turn 2700 rpm's at 70 mph. If you want to keep up with the 80-85 mph traffic on Texas interstates, I would recommend 3.21's.
1976 Feather Duster /6 4sp
1984 W100 318 727 np241
1972 'Cuda 340 4sp
1985 D250 360 46RH
PostPosted: Sun Jul 15, 2018 4:36 pm
check the drivers door tag, it should say the axle ratio
joesnow AKA Dan
 Post subject: D
PostPosted: Sun Jul 15, 2018 9:37 pm
D
PostPosted: Mon Jul 16, 2018 6:11 am
I run my Dart at 3000 rpm all the time on I-95 100 mile trips at a time; = 60 mph. 3500 rpm = 70mph. It tends to use oil over 3000 rpm, but no smoke.
Users browsing this forum: Ahrefs [Bot] and 10 guests
