It is currently Tue Nov 18, 2025 2:58 pm
 Post subject: Re: my turbo valiant
PostPosted: Mon Jan 08, 2018 9:13 pm
Looking good! Do you have picture how you mounted LS coils? Or trigger wheel?
there are pics just above how the LS coils were done, i'll go for a dig and upload a few pics of both the trigger wheel and earlier stages of coil mount now for you though
PostPosted: Mon Jan 08, 2018 10:04 pm
i only did the mount like this for the coils due to having 2nd handies that someone cut one of the mounts off to do some kind of coil straight on plug setup, i'd have made the bracket to use both mounts if i had non modified coils
basically the only pics i do not have of the trigger wheel are where i skimmed the inside of the rear of the balancer for a flat mating surface for that adapter hub/ring that i made, and it bolts through the front of the balancer.
PostPosted: Tue Jan 09, 2018 1:21 pm
Thanks for pics, looks beefy enough 8)
PostPosted: Wed Jan 10, 2018 12:16 am
no problem, way overkill, just material i had laying around
