It is currently Wed Nov 19, 2025 9:16 pm
PostPosted: Sat Apr 07, 2018 7:39 pm
Is there any special steps that I need to take to assembling the bell, flywheel and clutch set up on my 833? Did not know about the "hidden bolts" on the 11" bell when I was removing it. That was fun trying to find those sneaky little bastards. Can I just mount the flywheel to the crank and work my way out from there or do I have to have the bell mounted and slide the parts inside after mounting? Thanks in advance.
PostPosted: Sun Apr 08, 2018 1:34 pm
With the A833OD it goes together just like a passenger car. Flywheel, clutch and then bellhousing. No hidden bolts. No assembling the clutch after the bell housing is in place. It also means a lighter duty clutch, a hole in the floor for the shifter and a different starter.
PostPosted: Sat Apr 14, 2018 8:18 pm
Car Model: 1966 Barracuda
You putting the 4 speed on a / 6 or v-8?
PostPosted: Sun Apr 15, 2018 9:15 am
slant
