It is currently Mon Nov 17, 2025 11:18 pm
 Post subject: speedometer
PostPosted: Sat Jun 30, 2018 7:08 pm
I have a '67 dodge dart 2 door hardtop. My speedometer has a male threaded connection for the speedometer cable. I also have a speedometer that appears to be the same, fits in my gauge cluster, but does not have the threaded connection at the rear, rather it has what appears to be a quick connect type connector, similar to an air hose.
Anyone know what year that other speedometer is? I can dig it out of my stuff and get a part number if that helps.
Brian
https://tinyurl.com/yynpj4v2
 Post subject: Re: speedometer
PostPosted: Sat Jun 30, 2018 7:56 pm
67 was a transition year for the speedo connector. IIRC 68 and forward got the push-on connector and you need only order the later cable to adapt it to your 67. Others here will have more definite info.
. . . there was good sport at his making.
PostPosted: Sat Jun 30, 2018 8:37 pm
Thank you, Michael. Add that to the list of differences between '67 and '68 onward darts....
brian
