It is currently Wed Nov 19, 2025 3:11 am
Post new topic  Reply to topic  [ 81 posts ]  Go to page Previous 1 2 3 4 5 6 Next
PostPosted: Sat Jul 21, 2018 4:45 am
Car Model: 1984 Ram D150
New Holley is installed and running.
There is no hole available on the choke butterfly plate for the 1234 choke rod!
The only hole there is already used by the rod connecting to the fast idle cam.
Question: Do I need the choke plate connection to the fast idle cam if the electric choke is operational?
If I remove the connecting rod the fast idle cam will float, doing nothing...but maybe this is ok?
I called CarbsOnly, and they sent my case (with pictures) to their engineer, but they all knock off early on Friday and no one got back to me.
PostPosted: Sat Jul 21, 2018 9:14 am
Yes, you need a fast idle and a hole for the choke thermostat rod. Can you post the pictures here?
PostPosted: Sat Jul 21, 2018 9:43 am
Hi Reed, thank you.
Photos on my phone are too big and I'm without a PC or WIFI.
My choke plate has a slot and a hole, both of which already have rod ends in them.
The hole is the only place to logically use the choke rod end clip.
Options, as I see them:
1- use manual choke cable - the new carb has fittings and affixments for this option
2 - disconnect fast idle cam and use 1234 electric choke
3 - drill another hole in the choke plate, but there is not much room and I think there would be interference
PostPosted: Sat Jul 21, 2018 11:19 am
Here is a picture of a junk Holley 1945 I have. My finger is pointing at the hole where the choke thrmostat rod is supposed to go. The hole is in an eyelet that is behind the flange where the fast idle linkage and vacuum choke pulloff connect.
Hey! Whaddya know! Photobucket is working again! For free!
PostPosted: Sat Jul 21, 2018 3:21 pm
Thanks for the reply, Reed.
Yep, my old 1945 is like yours, in that it has the folded over portion with hole for attaching choke rod.
My new 1945...? Nope.
Too bad I can't use the electric choke unless I find a donor carb to swap out choke plates maybe.
My old carb's linkage asseblies were in rough shape. Hmmmm.
PostPosted: Sat Jul 21, 2018 3:36 pm
You can unscrew the choke valve and slide the choke rod out of the carb if you want to swap choke shafts between your old and new carbs. Heck, you want the one off that carb in the picture?
PostPosted: Sat Jul 21, 2018 5:44 pm
Very magnanimous of you sir, I will take you up on that. I just looked more closely at my old carb and the choke plate is not in the best shape and kinda wollered out.
PM inbound.
PostPosted: Tue Jul 24, 2018 9:12 am
Here is the best photo showing the 2 affixment points on the choke plate...one for the pull off and one for the fast idle cam and none for the 1234 electric choke. The choke rod is just laying there in the photo. Between Reed and I, we will get it hooked up soon and thank you for the assist.
PostPosted: Tue Jul 24, 2018 9:46 am
Ah. You have the choke thermostat rod in the hole for the fast idle cam lnkage and someone has straightened out the eyelet bend for the choke thermostat and affixed a manual choke clamp to it. You can try bending the eyelet back over so it looks like the one I posted.
PostPosted: Tue Jul 24, 2018 10:00 am
Well, this is reported to be a NOS carb, never been mounted or messed with which leaves me doubtful the manual choke affixment was added. It looks and feels completely factory, along with the mounting point for the manual choke cable. I am using a manual choke right now and wish to maintain capability of such for future reference (back up).
Here is another view, showing the manual choke cable mounting bracket and a wider view.
I see what you mean about the choke plate looking like it was bent, however.
PostPosted: Tue Jul 24, 2018 10:08 am
The report of it being a NOS carb is wrong. That is, at best, a remanufactured carb. That sticker was not put on that carb by Holley. Someone has definitely messed with that carb because the eyelet for the choke thermostat has been bent 180 degrees out of alignment. You can clearly see the waves in the flange for the fast idle linkage where the 90 degree bends used to be. Someone added the manual choke cable clamp, and mangled the carb doing it. You will not be able to run a manual choke and an automatic choke at the same time, and the automatic choke will not work with that bent eyelet.
PostPosted: Tue Jul 24, 2018 10:21 am
I was hoping the sticker might be a clue for someone.
The carb came from Tel Aviv, Israel so it could have been warehoused for military use or anything else (or rebuilt there).
The price was right @ $150 shipped, I thought (seller accepted my offer of same).
https://www.ebay.com/itm/232855442329?V ... 2855442329
I don't want to use both manual choke and electric choke at once, but I would like to maintain the capability to revert to manual choke if needed in the future.
Hence, the reason I think the choke plate you offered is a great solution to get the 1234 up and running without rebending (and possibly breaking) the *mangled* plate, which hadn't occurred to me before this minute.
Thanks!
PostPosted: Tue Jul 24, 2018 12:15 pm
Wouldn't be the first time an item was misrepresented as NOS.
We certainly can't believe everything we see and hear...never could.
Aside from the pictures, here is the seller's description of the carb.
NOS HOLLEY CARBURETOR H11945 HI1945 R8593 C7311 225" 198" Dodge Chrysler 1974-87
NOS NEW OLD STOCK ! THIS IS THE REAL THING !! NOT REMANUFACTURED. THIS IS BRAND NEW !!!
AUTOLINE C7311 is the remanufactured carburetor with retail price of $173 !!
you are bidding on BRAND NEW HOLLEY R8593 / HI-1945 CARBURETOR. 1 BARREL. NEVER BEEN INSTALLED.
SEE PICTURES. NO ORIGINAL BOX. JUST THE CARBURETOR.
fits the following models :
Chrysler 1975-1980 225" , 3.7L (Inc Repl Carbs)
Dodge 1974-1980  198" ,  3.2L, 225" 3.7L (Inc Repl Carbs)
Dodge Truck 1974-1987 , 225" 3.7L
Plymouth 1974-1980 , 198" 3.2L, 225" 3.7L (Inc Repl Carbs
limited quantity !! we ship worldwide.
Item specifics
Condition:
New
Surface Finish:
MERAL
Manufacturer Part Number:
R8593 , 8593 ,
OE Spec or Performance/Custom:
OE Spec
Other Part Number:
HI1945 ; HI-1945
Placement on Vehicle:
Front
Brand:
HOLLEY
Country/Region of Manufacture:
United States
Warranty:
1 Year
Type:
carburettor
PostPosted: Tue Jul 24, 2018 1:21 pm
I still don't buy it. I think you were taken for a ride on that description.
That being said, I will get the original choke shaft pulled and off to you ASAP.
PostPosted: Mon Aug 06, 2018 4:50 am
Thanks to Reed for sending me his choke plate / shaft.
It is in place, along with the 1234 electric choke and working as it should.
I am in the process of fine tuning choke adjustment for cold starts.
Once it starts easily and smoothly, I'll make an ignition key copy for wifey. :shock: :D
