It is currently Mon Nov 17, 2025 12:31 am
Post new topic  Reply to topic  [ 130 posts ]  Go to page Previous 15 6 7 8 9 Next
PostPosted: Tue Sep 18, 2018 7:22 pm
Awesome!
Still running a 528 cam in it as well I'm assuming?
Michael Glass. Mopar stuff and some rusty Mopar stuff!
1965 Dodge Dart with 66 Valiant front clip. Other stuff...
PostPosted: Wed Sep 19, 2018 8:56 am
Yes. .528 lift on 1.6 rocker ratio minus 0.028" or so for lash.
Rick... not sure on that yet.
PostPosted: Wed Sep 19, 2018 10:23 am
I guess you got a good one then. I've never heard anything bad about what kinda power it makes :lol: :mrgreen:
PostPosted: Wed Sep 19, 2018 12:09 pm
The last batch made were known for cam gear failures. I had one eat the pump gear in 800 miles. I did like the power though.
PostPosted: Wed Sep 19, 2018 12:42 pm
I guess this is an early batch one? 20k miles or so since install with dutra gear on pump.
PostPosted: Wed Sep 19, 2018 2:10 pm
The early ones seemed fine. I still have mine, I may try it again on a drag only motor. :mrgreen:
PostPosted: Wed Sep 19, 2018 2:27 pm
Cool dennis.. well it works on a street car too!
Wow this is the most action this thread has seen in 8 years :)
PostPosted: Wed Sep 19, 2018 6:07 pm
I think I replaced an old Racer Brown with the one I have. It made a ton more power.
PostPosted: Sat Sep 22, 2018 4:55 pm
Thanks for the input Greg and D.
I have one from about 1988. I was thinking about using it because I already have it :D
I'd love to hear it through open headers....
PostPosted: Sat Sep 22, 2018 5:03 pm
Well thenn...
https://youtu.be/hGxNHJqX4ls
PostPosted: Sat Sep 22, 2018 5:05 pm
Well...that was epic !! :mrgreen: :shock:
 Post subject: Rear Tire Change 2/18/19
PostPosted: Mon Feb 18, 2019 2:51 pm
Well 235 60 14's are a bit too wide for the stock 69 5.5" wide rims. Due to this they wear the center of the tread out quite a bit faster than the outsides.
I also had some help changing the tires:
The 235's were ready to be changed.. car is not driven much but when it is its a roadtrip machine. Also old tires were produced in 2006.
PostPosted: Mon Feb 18, 2019 3:10 pm
Cool! I can't believe you can still get BFG Radial T/As with similar/same tread pattern as 25 yrs ago! I assume the rubber compound is better. I ran 245/60-14s on the first iteration of the 64 Dart 1996-2001 or so on 7" SBP aluminium rims. Worked pretty well.
PostPosted: Mon Feb 18, 2019 4:03 pm
Yep they are timeless i guess.. possibly Corky Coker has something to do with it too.
PostPosted: Thu Jul 18, 2019 2:52 pm
Well I was beating on those tires.
As I work on building a road race corner carver type car..See Here:
I wanted to get into some events that are related to autoX, road racing or rallying.
Pittsburgh has a Vintage Grand Prix every year and as part of it they have a"countryside tour".
It's about 120 Miles of seasoned state routes, back roads, scenic byways and Mountain runs with twisty turns and elevation change. A stop for lunch and then an afternoon leg of the tour if you choose to drive in the afternoon heat for 60 more miles... I did not partake in that part. Oh and you kind of need a navigator to get through the route as they give you pace notes.
Typically they only take vintage European cars, and mustangs, although there was a corvair there.
It's a fund raiser so I thought my entrance fee is as good and the Porsche and MG guys.
Now I see why people love those 1500# MG's and Trumphs so much! There were 3 groups available: Brisk, Moderate and Stately. I chose Brisk, and Man it was a blast!
I was able to hang with the MG midget in front of me 'cept through some of the corners. It was fun. And this dart is not really setup for this stuff. The next one will be!
Pics:
