It is currently Wed Nov 19, 2025 10:42 pm
PostPosted: Tue Dec 18, 2018 5:53 am
Does any one have a picture they could post? I have a mount that I think might be correct, but I have never seen one, so not sure. Thanks
PostPosted: Tue Dec 18, 2018 7:32 am
I did, I'll find a pic, but on mine I removed the engine driven WP and used a remote electrical WP, which allowed me to relocate the mini alt. I'm happy with my solution.
PostPosted: Tue Dec 18, 2018 1:31 pm
Charlie I'm pretty sure someone posted one here in the last year or so, but I can't find it by searching!
PostPosted: Tue Dec 18, 2018 4:04 pm
There have been a couple of posts with pics, but I couldn't find them either.
PostPosted: Tue Dec 18, 2018 8:31 pm
I had one from an A-100 motor. I think Venables may have ended up with it.
PostPosted: Wed Dec 19, 2018 5:44 pm
here is an a100 mount. everything should be similar.
PostPosted: Wed Dec 19, 2018 7:04 pm
Thanks. That is different then the bracket I have.
PostPosted: Thu Dec 20, 2018 12:13 pm
I am sure that I am not the first one to think of this
weld washers on the block side of a power steering bracket,
to close the drop in slots,
get the spacing-pulley alignment right with spacers,,,
presto,,a driver side alternator bracket
PostPosted: Thu Dec 20, 2018 5:31 pm
Ok, try this one. This is my old one that I have on the Lancer. I even cleaned up the alternator!
PostPosted: Thu Dec 20, 2018 7:06 pm
Thanks. That looks like the one I have.
PostPosted: Fri Dec 21, 2018 2:38 pm
I have a 3rd style that came off my airport tug that had the alternator farther out from the block.
PostPosted: Thu Jan 03, 2019 2:48 pm
Here is the picture I knew I had!
PostPosted: Fri Jan 04, 2019 5:39 pm
this is this mount,
mounted on my car. It came off an A-100 Van with a Slant!
Works perfectly with a very short homemade harness.
1964 Dart GT
PostPosted: Fri Feb 01, 2019 5:26 pm
Here is the cast iron one from the 1980 Airport Tug. Even has a part number on it.
PostPosted: Fri Feb 01, 2019 6:51 pm
Car Model: 1975 Dodge D100
That’s a cool piece.
