It is currently Tue Nov 18, 2025 4:47 am
PostPosted: Wed Jan 02, 2019 12:42 pm
Car Model: 1960 Valiant V200
Done a lot of looking here and abroad but can't really find a clear answer.
My 1960 Valiant has the tilted A903 manual trans but no floor shifter and no clutch linkage. I do have the z-bar and trans side bracket but no frame side ball mount.
There is a guy local to me that is parting out a /6 1966 valiant manual trans with the column shifter.
Question is can I use any of the clutch linkage with the floor mount z-bar? Are they different between the earlier cars? I don't want to convert over to the column shift (I am aware that the floor shifter might be hard to source).
PostPosted: Thu Jan 03, 2019 1:06 pm
Having no luck finding info on the early transmission clutch linkages.
I should clarify that the z-bar I have has the three bolt frame bracket but I am missing the ball stud as shown here (circled in orange and pic cribbed from FABO)
Anyone know if that interchanges? Or the dimensions? Can't find anything online-lots of z-bar rebuild for 63 and up.
PostPosted: Thu Jan 03, 2019 1:08 pm
And the clutch fork linkage-is it specific to 60-62? The end looks different.
PostPosted: Thu Jan 03, 2019 1:45 pm
I never knew any of the transmissions were tilted??
Learn something new every day ! :D :D
PostPosted: Thu Jan 03, 2019 10:02 pm
The clutch fork looks like the one in my '65, which was originally from a '64 Dart. The ball stud may be available from the Mopar transmission specialist's. They do sell a version that bolts on. The nylon bushings for the z bar seems to be the same for all years.
PostPosted: Fri Jan 04, 2019 6:38 am
The best pic I can find that comes close to the setup.
The clutch release fork looks to have two eye fittings with the adjuster in the center. That I might have to fab up.
The upper clutch rod I am also missing. Just a matter of determining the correct length and offset.
Similar to this.
I don't see any reason that just any 9/16" coarse thread ball stud would work as long as it threads into the bellhousing.
PostPosted: Fri Jan 04, 2019 6:41 am
And the best tool I just picked up (for free I might add!) is a set of SAE tap and dies in both coarse and fine threads. Only up to 5/16" but already been chasing threads.
PostPosted: Fri Jan 04, 2019 9:32 pm
That's the same clutch setup as my '65 Dart uses.
