It is currently Thu Nov 20, 2025 4:04 am
PostPosted: Tue Mar 26, 2019 9:31 am
Car Model: 68 dodge dart 270 2dr
Hello - We bought a rear sway bar (Summit) for my 68 dart 270 and the brackets included wouldnt fit my 2 1/2" rear end housing...bummer...any suggestions?....or where to purchase the correct bar?
Thank You Slant 6 Forum
Happy Motoring
PostPosted: Tue Mar 26, 2019 1:46 pm
Which brackets ? Too big, too small ?
got a picture?
PostPosted: Wed Mar 27, 2019 5:53 am
sounds like you have a 7 1/4 rear end, all of the rear sway bars that I have seen are made for the
larger axel tubes used on the 8 1/4 and 8 3/4
if you really want to run the rear sway bay on a 7 1/4,,, have a fabricator or machine shop make you
2 cylindrical tube spacers that would bring your existing axel tubes up to the required diameter.
Then split the spacer tubes so they can be fitted to the axel, weld them in place and move forward with the
rear sway bar install.
and I have heard that one of the faults in the 7 1/4 is that it has a relatively small lube chamber, so if you plan to
do spirited driving with one, be sure to use a high quality differential oil and keep it serviced.
