It is currently Sun Nov 16, 2025 11:43 pm
PostPosted: Mon Feb 18, 2019 10:28 am
Car Model: 1969 Plymouth Valiant 225 \6
Hi everyone. I hope all is well with you and your rides. Inspection has come up and I need a complete exhaust for my 225 slant Valiant, less the manifold. I'd like to keep the same diameter as the manifold so it doesn't get choked down. Can anyone recommend a system that is an easy bolt-on and is reasonably priced? Thanks for the help.
PostPosted: Tue May 14, 2019 1:48 pm
Car Model: 1967 slant 6 signet 4 door
http://www.accurateltd.com/1963-73-225- ... _c_71.html
I have this exact one worked out well 2 1/4 inch :)
PostPosted: Tue May 14, 2019 6:19 pm
I'm kind of keen on "quiet" in my older age. How noisy is that from inside? One of our cars has a custom fab'd larger exhaust that gives a floor board rumble at lower speeds and drone on the highway.
PostPosted: Tue May 14, 2019 10:00 pm
Car Model: 1982 D150 225, 2bbl., 833 OD
http://www.accurateltd.com/1963-73-225-Slant6-All-Models_c_71.html
A couple more sources. No experience with either.
TTI mandrel bent at Mancini ( maybe other vendors).
https://www.manciniracing.com/coslsiexsyno3.html
Waldron, also many other Mopars.
http://waldronexhaust.com/cart/index.ph ... =61_52_113
1982 Dodge D150 ( Ram)
225 with A833OD. 2bbl. Non power brakes
Users browsing this forum: No registered users and 43 guests
